I had a 2015 slim that gave me fits, shutting down while cruising along, not starting, lights flashing on and off. It turned out to be the on/off switch on the tank. After I replaced that, I had no problems. It got to a point over time where it would start sputtering, lights flashing where I could wiggle that switch around and either correct it, or cause it.
So this is my original thread. So like I said in the last post, the bike starts correctly but it is in limp mode. I have no throttle response. I disconnected the negative battery cable overnight to let the ECM reset. Didn't work.
The BCM that I bought from ebay has the same axis and the same model number I think that I may have to have it paired with the ECM.
Any thoughts from you guys.
Last thing I do have my Pro Street Tuner and the software can I use this to try and fix the issue?
What diagnostics lead you to believe you needed a BCM?
Any diagnostic codes?
To specifically answer your question, any time you change an ECM or BCM, there is a required procedure. I believe Harley calls it a "Password Learn" procedure, needed for proper communications between the two modules.
It can be done by the dealer's computer (Digital Tech II), an independent shop or friend with a TechnoResearch Centurion Pro diagnostic tool, or there may also be a customer manual entry procedure, rather long and specific, like with the old TSSM. I'm just not sure about a customer procedure for the BCM..
What lead me to the conclusion that it was the BCM is that I checked the wiring harness and found nothing wrong with any of the wires. The BCM that I bought from ebay when hooked up the bike starts correctly. The original BCM when hooked up starts the bike with everything in the off position.
