FAT baggers ez adjuster-slams into first
Old Nov 7, 2024 | 05:15 AM
FatboyCrimson's Avatar
FatboyCrimson
Default FAT baggers ez adjuster-slams into first
Hi everyone,
my stock upper clutch cable failed, red clip broke and a new one wouldn't hold adjustment. Clutch was working fine. I installed the Fat baggers ez adjuster and lower tube and now it dlams into first gear as if the clutch wasn't fully disengage. I have tried adjusting the clutch basket atbthe primary to no avail. Please help.
Old Nov 7, 2024 | 05:19 AM
702's Avatar
702
There are 2 different parts based on year & model. Did you use the correct one?
Old Nov 7, 2024 | 05:35 AM
FatboyCrimson
Yes I did. Went off there website. Part
Old Nov 7, 2024 | 05:53 AM
FatboyCrimson
Part 108911, ordered through jp cycle. So.im pretty sure I git the right one. Also confirmed on FB website
Old Nov 7, 2024 | 06:01 AM
GalvTexGuy's Avatar
GalvTexGuy
Did you follow the instructions?
https://fatbaggers.com/media/fbcatal...structions.pdf
Old Nov 7, 2024 | 03:05 PM
702's Avatar
702
You got me curious, so I just went and installed one in my 22 Heritage that I've had on the shelf forever. I have no issues. Did you adjust the clutch inside the primary?
Old Nov 7, 2024 | 03:20 PM
gonemad's Avatar
gonemad
I’ve installed two of those on two late model M-8 touring bikes. I don’t think I even bothered adjusting the clutches on either, because both bikes were so new at the time of installation.
If the only thing you changed is the cable adjuster, I think that is where your issue is, and I’m guessing it just needs more adjusting. Get a factory service manual if you don’t already have one.
Old Nov 7, 2024 | 04:27 PM
FatboyCrimson
Update,
I called FB tech support and they advised to redo the primary clutch adjustment. Keep an eye on the ferrule, it must be pushed all the way down on the lower clutch cable after backing out the adjustment bolt 3-4 turns. Worked like a charm.
Maysen27
May 5, 2024 11:18 AM
Fullbore55
Jan 30, 2024 07:16 AM
mike_snoo
Nov 30, 2021 07:48 PM
SavageChopper
May 1, 2018 02:01 AM
