milage on rear tire of 07 custom
Old Sep 4, 2007 | 03:38 PM
buckshot's Avatar
buckshot
Default milage on rear tire of 07 custom
just curious to see what all of you are getting for milage out of your 07 custom tires?
I have 4400 miles on my bike and the tire appears that it will need replaced soon
Is that normal?
Old Sep 4, 2007 | 03:39 PM
anubisss's Avatar
anubisss
Default RE: milage on rear tire of 07 custom
Seems kinda low. Have you been checking the tire pressure regularly?
Old Sep 4, 2007 | 03:42 PM
Finn111's Avatar
Finn111
Yea, that doesn't sound right. I've got 4700mi. on my FXSTC and it's still in good shape. I did loose the wheel weight, at 1000mi. but I replaced it.
Old Sep 4, 2007 | 06:30 PM
dg7080's Avatar
dg7080
Replaced mine at 9200. Probably could have gone a few more miles, but had a 1200 mile trip to do, so I replaced it..
Old Sep 4, 2007 | 06:33 PM
Crazy Biker's Avatar
Crazy Biker
I have 6700 miles now and I think I'll change it at about 8000 miles.
Old Sep 4, 2007 | 07:05 PM
Spike_96's Avatar
Spike_96
What pressure are all of you using? I've been told that going with the manf.prescribed pressures tends to leave them underiflated, and cause premature wear. I have no idea ig\f there's any truth to it though.
Old Sep 4, 2007 | 07:21 PM
frisco42's Avatar
frisco42
At about 5800 miles I replaced the oem Dunlop with a 210 Metzeler. Here's a picture of the old and new tire.
http://frisco42.home.comcast.net/REAR.JPG
There may be another 1500-2000 miles left on the old tire, but I've had good luck with Metzlers.
At 4800 miles I put a 90/90 Metz. on the front. The Dunlop front was worn out on the right side due to the several right turn cloverleafs on my daily commute route.
Old Sep 4, 2007 | 08:53 PM
Rich C's Avatar
Rich C
If I am not mistaken, I read somewhere that you should get about 10,000 on a tire. Course at 2800 miles I got a roofing nail, that sucks.
Old Sep 4, 2007 | 09:10 PM
detonator's Avatar
detonator
My tire is ready to be changed and it has 4,544mi. That is the stock 200mm tire and it does still have tread but not enough if youwant free tires for life which is in affect for 2007 C.V.O. bikes. I think that gos for all models in 07? the tread can only go to 2/32 I believe.
Old Sep 5, 2007 | 02:12 AM
O6FXST's Avatar
O6FXST
Mine was completely gone at 7500, but... then again I am alwaysCRANKIN ON IT!
