ThunderMax / Reinhart Question
Old Sep 4, 2007 | 07:49 PM
JJG123's Avatar
JJG123
Stage IV
Default ThunderMax / Reinhart Question
I just had Reinhart flush exhausts with the thundermax auto tune installed on my 2007 Deluxe. I noticed that the check engine light came on once my oil temperature reached 170. This never happened before with the stock Harley ECU and exhaust. The temperature did get to 170 before but the check engine light never came on. The performance shop told me that the stock Harley ECU was incapable of turning the check engine light on when the oil temperature reached that high. Does this sound correct, or is this guy trying to pull one over on me? He did reprogram the ThunderMax and now the temperature does not get above 240, and runs very strong. I just want to know if I can trust him for any future mods.
Thanks.
Old Sep 4, 2007 | 07:51 PM
JJG123's Avatar
JJG123
Stage IV
Default RE: ThunderMax / Reinhart Question
I meant 270 not 170.
Old Sep 4, 2007 | 11:47 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
He may well be right as more than a few guys on here have reportedseening 270 with no mention of the check engine light coming on with stock ECM's.
Old Sep 5, 2007 | 08:21 PM
JJG123's Avatar
JJG123
Stage IV
Thanks, I was hoping that he wasn't trying to scam me.
Old Sep 5, 2007 | 08:37 PM
You can always check with Zippers, I'm sure they would knowexactly what their own ECM can and can't do compared to the stock unit.
Old Sep 5, 2007 | 10:02 PM
bdavis385's Avatar
bdavis385
According to the Tmax manual, it does not come on based on oil temperature but head temperature and then at 325 (the default setting) but it can be set to any number you want. Evidently 325 is consider dangerous and it says you should immediately stop. My oil temp never gets over 225, but I live in the NW and it does not get all that hot here.
Old Sep 5, 2007 | 11:56 PM
I wonder if your oil temps are higher than you think, or the ET (engine temp) sensor is a little screwy and reading or sending out artifically higher readings than it should.
Old Sep 7, 2007 | 05:53 PM
JJG123's Avatar
JJG123
Stage IV
Will the stock Harley ECU also show a check engine light when the head temperature reaches a certain point?
Thanks again.
iDodgimus
Jun 4, 2014 08:27 PM
robynbobln
Jun 11, 2010 07:55 PM
Bad Pig
Jul 30, 2008 02:01 AM
fatmouse
Jul 20, 2007 10:17 PM
baron3547
May 5, 2007 02:18 AM
