TSM/Turn signal module
Old Jun 26, 2025 | 03:05 PM
Jakester68's Avatar
Jakester68
4th Gear
Default TSM/Turn signal module
I had a left rear blinker issue. All other 3 blinkers worked as normal. I fixed the broken wire, now I have no blinkers? Not sure what could have happened, but am wondering if the TSM is bad now? Do you check it by seeing if there is 12v in, and hit one of the blinker buttons and if there is no pulse out is that mean it is bad? 2010 Fatboy Lo, thanks
Old Jun 27, 2025 | 07:29 AM
WKNDS's Avatar
WKNDS
I just saw this about a week or so ago. Just in case you need to replace yours....
I have no affiliation with CD....
https://www.customdynamics.com/motorcycle-accessories/electrical-modules-wiring-accessories/tsm-tssm-replacements-for-harley-motorcycles
hth,
T.
Old Jun 27, 2025 | 07:37 AM
Rounders's Avatar
Rounders
I don't know how the blinkers work but for my bikes the starter and igniton enable from the TSM is done by grounding signal.
But think about it, you fixed a broken wire and still doesn't work. Something ain't right. Recheck your work. Ohm pins form end to end.
Broken wire and bad TSM is a lot.
I would buy harley TSM it works with your check engine light, to my knowldege, on my older bikes it does not.
Old Jun 27, 2025 | 07:59 AM
Jakester68's Avatar
Jakester68
4th Gear
I found the issue, the "accessory fuse" was blown. I must have done that fixing the wire to the blinker. Just to let you know, the 2010 fatboy blinkers are powered by that fuse.
Old Jun 27, 2025 | 08:26 AM
hattitude's Avatar
hattitude
hth,
T.
Thanks for sharing this info...
I heard CD was going to offer replacement TSMs, glad they have arrived...
Old Jun 27, 2025 | 08:27 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Thanks for getting back. Added your post to the TSM/TSSM Folder
Old Jun 27, 2025 | 09:12 AM
Uncle Larry's Avatar
Uncle Larry
FWIW ... The Custom Dynamics TSM will require a Technoresearch Tuner to complete the installation
sperryfish
Aug 10, 2022 08:38 AM
icreepin
Jun 11, 2020 09:42 PM
Pequeapa
Aug 1, 2013 04:04 PM
bbo626
May 27, 2010 05:43 PM
Helge
EVO
Apr 28, 2010 03:09 PM
