Faulty switch
Old Aug 26, 2025 | 08:27 AM
rjgordon0's Avatar
rjgordon0
6th Gear
Default Faulty switch
Hey guys, asking on here for a grounded rider. His 2011 Softail convertible CVO has a non functioning start button. He has tried everywhere but the part number 71110-11 is coming back as obsolete & the switch is no longer available. Does anyone on here know if there is one kicking around anywhere please ?
many thanks
Bob
Old Aug 26, 2025 | 09:26 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Two quickies for him. Take it apart and see if it is just in need of cleaning the contacts. Second, Ebay.
Old Aug 26, 2025 | 09:32 AM
08xl1200r's Avatar
08xl1200r
In a pinch he could install a starter push button on the end of the starter solenoid, they will start the bike if the start switch, relay, or wiring fail...have one on my own bike as backup.
That would get the bike going until the root problem is fixed.
Old Aug 26, 2025 | 09:44 AM
rjgordon0's Avatar
rjgordon0
6th Gear
Hi, thank you for the suggestion. We have looked at this idea along with a separate handlebar mounted push button switch & also looking to see if the switch can be repaired by a specialist 😬
Old Aug 27, 2025 | 07:48 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
It's a simple switch. As a band-aid to get moving again, de-pin or even cut the wires at the connector. Splice in a normally open momentary contact switch. Hobby shops carry these switches.
Worse case, just leave the two wires sticking out, and touch them together to make the circuit and the starter motor spin.
Old Aug 27, 2025 | 08:12 AM
Mongo1958's Avatar
Mongo1958
Has anyone verified if the engine kill switch is in the correct position?
Old Sep 3, 2025 | 06:26 AM
panhead_pete's Avatar
panhead_pete
Always used switch blocks etc available on eBay you could source one from but before that have you tested the switch?
GTK
Jun 16, 2021 09:23 PM
Hoginedgewood
May 18, 2020 05:54 PM
Crueguru
Aug 26, 2014 11:00 AM
Lylemonroe
Jul 26, 2013 02:52 PM
rwrimes
Jun 16, 2011 09:50 PM
