oil leak problem
Old Nov 14, 2025 | 02:25 PM
buzzard53's Avatar
buzzard53
Well, I finally have the leaky trans drain bolt fixed.
I want to thank everyone for the helpful suggestions I tried the stat o seal washers without success as the OEM drain bolt was still not running up straight and level in the hole. I had my ASE certified grandson come over to lend his expertise. He verified the threads in the trans case were toast.
He found me online an oversized 1/2 -20 self -tapping, piggy back magnetic drain plug.
We raised the rear of the bike to gain some extra work room.
Applied a heavy dose of blue gel loctite to the threads and carefully ran the plug up into the drain hole until we had a good, solid fit. Let it dry over night then inserted the piggy back insert with some teflon tape and tightened it well.
Refilled the tranny and after two 45 mile rides everything is dry!!
I was really worried that I was facing a transmission case replacement job.
Really happy to have saved big $$$
mltdwn
26
Oct 21, 2025 10:57 PM
Gibby13
Jun 26, 2023 11:31 AM
skeazle
General Topics/Tech Tips
Feb 4, 2018 01:46 PM
Panthers65
EVO
16
Oct 29, 2016 08:29 PM
KJB
Jun 6, 2014 06:52 AM
