Tire Load Rating
Old Jan 7, 2026 | 08:55 PM
bulldog1776's Avatar
bulldog1776
Default Tire Load Rating
The frame sticker on my 95 Bad Boy Springer says front tire load rating is 56H and rear tire is 74H.
That exact rating is hard to find in the oem sizes ( MH90-21 and MT90-B16 )
Will 54H on the front and 73H on the rear be fine? I only ride solo.
Thanks guys.
Old Jan 8, 2026 | 05:17 AM
eighteight's Avatar
eighteight
54H = 467lbs
73H = 805lbs
Combined = 1272lbs
Bad Boy = 608lbs
1272 minus 608 = 664lbs
Do you weigh less than 664lbs ?
Old Jan 8, 2026 | 06:23 AM
Schex's Avatar
Schex
I don't know where you're seeing those ratings, every MT 90b-16 I see is 74H
https://www.americanmototire.com/str...le_semantics=1
also the MH90-21 is 54H, a couple 56H
https://www.americanmototire.com/str...90-21%22%5D%5D
Old Jan 8, 2026 | 07:15 AM
touchdown's Avatar
touchdown
You should be fine, you can even pick up a fat girl now and than.
Old Jan 8, 2026 | 07:22 AM
eighteight's Avatar
eighteight
^ or two at a time
Old Jan 8, 2026 | 09:04 AM
bulldog1776
Thanks guys, yeah I figured it would be ok. Maybe the tires have changed some since 95
LQQK_OUT
Wheels/Tires
13
Sep 27, 2021 12:10 PM
FurryOne
Jul 30, 2016 06:39 PM
jackhis
Nov 21, 2012 10:01 PM
SinisterX
Sep 8, 2012 09:17 AM
antman27
Jun 27, 2011 12:20 PM
