2001 FLSTI
Old May 6, 2026 | 07:58 AM
Maltesefalcon's Avatar
Maltesefalcon
Default 2001 FLSTI
Hi All
I have a 2001 Heritage Springer with a ticking noise. When I have it idling no ticking sound when I throttle the gas no ticking sound either. Start riding it and going down the road it starts ticking and sometimes loud. Let the throttle go and it stops. The sounds seams to be coming from the front cylinder but not completely sure since it only happens when I'm riding. Was wondering if anyone had anything like this happen. The guy I bought it from was the original owner and the bike is bone stock with just 10k miles. He said the mechanics at the dealer he use to take it too told him not to worry some Harley bikes do that. I have 5 Harleys and none of them ever had a ticking sound like this. Any help would be apricated.
Old May 6, 2026 | 10:57 AM
eighteight's Avatar
eighteight
Is the ticking speed related to the speed of the bike ?
If it only ticks when moving, you can dismiss the engine and concentrate on the driveline
Old May 6, 2026 | 11:50 AM
hattitude's Avatar
hattitude
The way you describe it, sounds like drivetrain rather than engine, but you'll want to verify where the sound comes from.
Start with the easy stuff... Inspect the drive belt, and pulleys......
Also, since it seems to tick only under load, check for exhaust leaks at the exhaust ports..
Without hearing it, and/or a better idea where it's coming from, that's the best I can offer...
Old May 6, 2026 | 01:16 PM
2goldens's Avatar
2goldens
Good point. I’ve heard leaks at the exhaust manifold on cars sound just like a lifter tick.
Old May 6, 2026 | 01:55 PM
Jackie Paper's Avatar
Jackie Paper
What type of front wheel is on it? Some of those fat heavy chrome spoke wheels tick.
Old May 6, 2026 | 04:43 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
My first thought after reading the description was Detonation under load. But the suggestions of an exhaust leak are sure possibilities. Specifically, the front cylinder exhaust port since you stated it sound like it was in the frontal area.
Old May 6, 2026 | 05:59 PM
Maltesefalcon
Thanks. Checked the primery belt looks fine but will do a thorough check. Will open the primer cover and also check.
Old May 6, 2026 | 06:04 PM
Maltesefalcon
Thanks will do
Old May 6, 2026 | 06:07 PM
Maltesefalcon
Thanks I will also take a look at the exhaust. It is very annoying because I only hear it when Im riding the bike.
Old May 6, 2026 | 06:10 PM
Maltesefalcon
It really does sound like a loud lifter tick when I hit the throttle and when I let go the tick is not that loud.
