clutch cable "stretch"?
Old Oct 2, 2007 | 06:20 AM
banjo's Avatar
banjo
Default clutch cable "stretch"?
Hi
My 2007 softail std. has just done about 600miles (1000klms) from new, and I have had to adjust the clutch cable twice now and to-day I noticed that there is play in it again! and the gear change is dragging and noisy!
Is it the norm for the cable to stretch like this or is something else likely to be going on in the clutch itself ?
Brian Perth W Australia
2007 Softail std.
SE slip-ons
Mustang seat
Old Oct 2, 2007 | 07:59 AM
Navychief's Avatar
Navychief
Default RE: clutch cable "stretch"?
Sounds a little premature to me.
Old Oct 2, 2007 | 01:11 PM
nvsteve's Avatar
nvsteve
I adjusted my cable twice then wound up adjusting the clutch. Been fine for about the last 4k miles.
Old Oct 2, 2007 | 04:46 PM
Bikenator's Avatar
Bikenator
From: in a trailer next to a ditch in South Florida
ORIGINAL: banjo
Hi
2007 Softail std.
SE slip-ons
Mustang seat
Dealer adjusted my clutch inside primary housing. Need to remove Derby cover, adjust clutch per manual. They did this as part of 1000 mi service.
I told them clutch handle had normal tolerance of 1/8" but they said not cable adjustment...then did the clutch itself. Worked fine. No dragging, clean engage/disengage. Hope this helps.
[IMG]local://upfiles/36782/89EF765568DB4E8EA23A10031FDADF27.jpg[/IMG]
Old Oct 3, 2007 | 07:12 AM
banjo's Avatar
banjo
Thanks guys, I suspected that it may need the actual clutch adjusted and not just the cable.
Hopefully will be ok till the first service.
Brian
thanoskazakos
Aug 11, 2018 08:48 AM
sg34
Sep 18, 2016 12:16 PM
dandrumheller
Jun 16, 2016 09:39 AM
rdondes
Oct 23, 2013 08:16 PM
simmonsp5
Jun 27, 2011 04:22 PM
