FXSTB WITH 49MM FORKS?
Old Oct 10, 2007 | 06:02 PM
FXSTBO8's Avatar
FXSTBO8
Default FXSTB WITH 49MM FORKS?
Just a quick question, will the new 49mm front end of the Dyna bikes fit on the NT neck frame..? I like the fat forks of the Dyna bikes and just wondering if it might work......Thanx
Old Oct 10, 2007 | 06:33 PM
dipshyt81's Avatar
dipshyt81
3rd Gear
Default RE: FXSTB WITH 49MM FORKS?
I posed this same question about six months back before my last "log on ID" got banned. If I recall no one really knew.
That dyna front end seems like it would be the perfect blend for the fx's ! More rubber on the road and beefy looks.
hopefully someonw knows now or maybe even has done it, with pics?
Old Mar 25, 2012 | 03:38 PM
mike lhc's Avatar
mike lhc
Anybody do this yet?
Old Mar 26, 2012 | 06:59 AM
MCSarge's Avatar
MCSarge
The Dyna front end is wider between the trees than a softail. But since you can slide the bottom tree up you only have the pivot bolt to deal with. You might be able to turn it down in a lathe and rethread it. I had to cut the pivot bolt down when I put a Softail front end on my FXR. Only had to cut off 3/8".
Now that being said, you are going to have to come up with some fork stops, and the fork lock probably won't work without modification or at all.
Bottom line can you do it, Yes. Now how much do you want to spend to make it work. Good luck on your project.
Old Feb 16, 2024 | 06:51 PM
Soulz76's Avatar
Soulz76
6th Gear
I have 49mm front end in my 02 Night Train fxstb
49mm front end
49mm front end
Old Feb 16, 2024 | 09:10 PM
Harley_ish's Avatar
Harley_ish
You might want to measure those tubes ... looks like Std 41mm tubes
Old Feb 17, 2024 | 03:59 PM
OLD REK's Avatar
OLD REK
My '08 Rocker C has 49mm tubes.
24v
Jun 28, 2013 02:37 PM
lilsahara450r
Mar 7, 2010 10:17 AM
roofer
Feb 23, 2009 08:57 AM
Solitario
Jun 3, 2008 03:09 AM
IDI
Dec 20, 2007 09:36 AM
