Which side does your softial lean to?
Old Oct 19, 2007 | 07:49 PM
VETTE68327's Avatar
VETTE68327
Default RE: Which side does your softial lean to?
MINE GOES STRAIGHT, MILE AFTER MILE AFTER MILE.............................................. ................
Old Oct 19, 2007 | 11:15 PM
Texas Fat Boy's Avatar
Texas Fat Boy
ORIGINAL: chivohead666
My 07 train leans to the left
I didn't know Night Trains were democrates.
DAMN ??????
Old Oct 20, 2007 | 12:38 AM
Solitaree1's Avatar
Solitaree1
My 07 train leans to the left when I ride and let go of the handle bars. No problem while riding just curiosu to see if its normal. I have apes and saddle bags. Leans to the left only when I let go of the handle bars.
Mine veers to the left when I ride and let go. At first, I couldn't figure out why. Then it dawned on me.
It's all the extra weight on that side of the bike. Due to placement of family jewels.
Old Oct 20, 2007 | 06:34 AM
Trotter's Avatar
Trotter
Only on the Left coast
Old Oct 20, 2007 | 08:15 AM
GrampsWyatt's Avatar
GrampsWyatt
I know on the 07 FLSTF w/200 tire, to get the motorbike to track or align the tires, they did in fact have to move the front tire over to the right/exhaust side. You can in fact see when you stand in front of the motorbike, look at the fender space from the fork on both sides of the tire, it is a good 1/4-1/2" more on the left side as you sit on the bike. I have heard this is not the case on 2008's. I am not sure if it is so on all softails with 200mm rears in 07 though, it is the case on the fatboys though.
Check alignment on rear, measure distance from pivot bolt (swingarm)to center rear axle on both sides, I think 1/4" or 1/8" (not sure which one)or lessdifference is ok, check your manual though.
Old Oct 20, 2007 | 09:08 AM
rbabos's Avatar
rbabos
For what it's worth my 07 fxstc has the wheel shifted 5/16" to the right.
Ron
Old Oct 20, 2007 | 10:02 AM
deadman77's Avatar
deadman77
Mine goes straight. Never saw the need to ride with no hands.
MikeM
Old Oct 20, 2007 | 10:21 AM
flstcbob's Avatar
flstcbob
My standard has been pulling to the left ever so slightly. I had previously checked the wheel allignment by measuring between the axle and swingarm pivot. Yesterday I tried the string method and found it took a half turn on right side adjuster to get it perfect. I'll find out today if it helped. My front rotor is warped which could alsobe causing it. I need to replace that and change fork oil to make sure they are even which may also affect it. My previous heritage and nightrain tracked straight as an arrow, so I know it's not normal.
Old Oct 20, 2007 | 02:31 PM
spike95's Avatar
spike95
Mine has always leaned left. I've checked the rear wheel alignment and my mechanic has checked it too. Looks like it is right on, but I adjusted it a little bit and it seemed to help some. I wondered if it is from removing the heavy @ss stock exhaust system. Maybe this has to do with certainparts of my anatomyleaning to the left?
Old Oct 20, 2007 | 03:34 PM
OldFenderGuy's Avatar
OldFenderGuy
ORIGINAL: Trotter
Mine leans to the left when it's on the stand ! does that count...
Mine leans to the right when it's on the stand....
Guess they were having a 'bad day' when mine was built. [8D]
