05 softail vs 93 electra glide classic
05 heritage softail classic (FLSTCI) -
right color
v & h straightshots slip on muffers
low miles (less then 10k), first 5k service done by hd certified mechanic but not at dealer so not sure if warranty would still be honored by hd
one owner
a few extras and has all original parts as well as part of the deal
$15,000
ok color (black with red/orange tank decal and red/orange pen strips)
radio/bat fairing but no truck
fish tail exhaust and maybe a stage one kit on it
brother says it is in very good shape
history not really known to speak of and has been sitting for around a year in a garage
40k miles
$7,000
Me -
1. Don't know that now is the time to get deeper in debt (is there ever a good time).
2. Sold the 07 rk std after only 1k miles (yes lost money and yes one should not buy then sell right away)
3. Did not like the heat given off of the rear jug on the new 96cc engine, brakes and suspension where ok but not great; maybe sitting on top of the bike instead of in it gave that feeling a bit. Stock seat sucked (imo). Power and shifting was fine. 5th/6th gear noise was bearable (not a deal breaker but indeed 2 thru 4 were nice and quite); 6th gear just seemed geared too high for much use unless on highway.
Never owned a softail but would consider one for this color. Like a radio, wind protection, bags to put junk in (though very little space compared to my gl1800...yes I know two different bikes).
What I would like to hear about:
How different is the 93 engine compared to the 05?
How will the ride feel comparing the two?
(Brother has a 97 softail so i could ride it but figure it won't be the same as the 05 plus his strucks? were switched out which makes his bike even lower/closer to the ground then a stock softail).
Might either bike run cooler then the other (assuming stage 1 kit on 93)?
Is the 05 pipes going to be too lound (or even legal)?
Last, I'm really not into a lot of heat kicking up off the rear jug and though the bat wing fairing effects air flow (the 05 has the rk type windshield) I figure either the 93 and 05 are equal concerning heat thrown off or they are different.
Sorry for the long post but trying to give enough info so you know both what I'm comparing, differences I need to know, and why a 96cc just won't do it for me.
So, tell me am I just wishing for a hd ride again but wont' be happy with the heat or might either of this give me a hd fix without the extra heat the 96cc kicked off?
thanks
Actually I did not find I disliked the rk riding position per say it was just that I was more aware that I sat on the bike instead of lower in the bike. When doing a demo ride on a electra glide I find the seating position and seat just fine really and for what ever reason 'think' I'm sitting lower (as in 'in the bike') instead of on top of the bike. Guessing the seating position between a rk and egc probably are almost the same but it feels better on the electra glide classic to me.
Cost is a big factor once I stop to reallly consider it for awhile. I have a bad habit of, once I find what I did not think I could , (as in the special color hertiage) I then say 'that is it, I must have it' but in the real world I should really consider just how dam long it will take to pay it off.
The big thing for me is to just understand how each engine will be different from one another. It seems the 80cc was a solid engine for the most part back in 93 and just read a review of a 06 dyna wide glide (point being that in it they spoke about some owners having issues with cam bearing failures though this seemed to effect the twin cams when that engine came out in 99...if I have that correct).
Most likely, once the lady gets the replacement key made later this week I will ride the classic and if it feels right and looks in really good shape then take it to local dealer and ask that they give it a 'once over' to confirm no issues are noticed. Then buy it I would think if it 'moves' me the right way.
I'm guessing the 05 engine is just a bit tighter and all the bites and pieces designed a bit better then the 80 A engine and like wiseI'm sure the 96cc engine better in the same waycompared to the 88 B engine. Not sure if my brothers 97 heritage engine is counter balanced or if that was done in later year softail models (04..05 ?) so if I ride his it may not really let me know whata 05 softail rides like.
Anyway, with luck the 93bike won't be as hot as the 96cc was. The 93 is cabs so it is old school (not to say that is better or not but it is what it has).
Will keep you posted on whatI do.
thanks again
The evos run much cooler, avg around 180 degrees, the TC88 will run at least 220 degrees, the 96 even hotter. I think the fairing makes it even hotter.
None of the evos are balanced, started that in 2000 with the TC88B, the evo has way more tork than a stock 88 and is comparable to a TC95.
Lots' of cream puff evos out there, look around. I saw a 1994 FXSTC (not what you're asking about) go for $7800 on ebay this week. Also a 1998 Fatboy last week for $8500, comparable to the Heritage. Lots of good bikes out there for under 10K.
Also longevity would be a concern of mine the evo (unmolested) will run 70-100K with no work needed. I doubt you will see anything like that from a TC engine. My buddies cam tensioners needed replaced at 15k. How long is the chain gonna last on the balancer? Complete rebuild if that goes.
I myself prefer the softail frame to the FLH. It feels more like you are part of the bike as opposed to sitting on top of it. To each his own.
If money is the issue get an older model, they are everwhere and not selling. make a lowball offer. You may get lucky.
The sellers market sucks right now and ain't getting any better until at least spring. I know, wanna buy a 94 FXSTS?
"I ride an evo softail, the mirrors are just for looks!"
1. The Evo (84 thru 98) engine runs cooler then the newer ones (99 onward).
2. If the 93 has a Stage 1 kit then it could have any of the following:
free breathing air cleaner, free breathing exhaust (i.e. the fish tail mufflers), rejetted carb [did a search] [8D]
If it has any/some of above then engine would run hotter or cooler due to more air/fuel/opened up exhaust ?
I'm guessing cooler
3. The 93 is I'm guessing a rubber mount engine but not counter balanced. My brothers 97 softail is a frame mout engine that also is not counter balanced. The 05 is of course counter balanced ridge mounted engine.
Like I said, I have a '05 rk custom, and my bike has a carb. I actually looked for a bike with one, so I can relate there, as well.
