69461-06A light kit for rear lights ????
Old Oct 29, 2007 | 08:30 PM
voyager1's Avatar
voyager1
Default 69461-06A light kit for rear lights ????
anyone have this on 07 or 08 heritage ? I am not sure. this part number work ok on a 2008 ?
Turn signal module adds an auxiliary brake light and running lightfunction to your existing turn signals for auxiliary rear lighting.Red lenses glow when the headlamp is on, and increase in intensity when brakes or turn signals are activated. Easy-to-install, the kit simply plugs into your existing wiring harness. Red turn signal lenses are included. Meets DOT requirements. Fits 96-later Softail models and 97-laterTouring models equipped with OriginalEquipment flat lens style turn signals. (Does not fit with Narrow Chrome Directional Bar P/N 68611-98)
Flat Lens Style.
Required Kit Part Number(s):
Thanks for any advice !!!!
Old Oct 29, 2007 | 09:28 PM
voyager1's Avatar
voyager1
Default RE: 69461-06A light kit for rear lights ????
No one have this ?
Old Oct 29, 2007 | 09:59 PM
Bowtieman31's Avatar
Bowtieman31
Yep, I have one on my '03 Heritage and on my '07 Heritage. They work differently on each bike. On the '03, the turn signals have the red lenses but only illuminate when the brakes are applied and when the turn signal is activated. On the '07 the turn signals are on all the time as running lights, then get brighter when the brakes are applied or the turn signals are activated. Both ways, make you more visible and thats a safety issue.
Old Oct 29, 2007 | 10:05 PM
voyager1's Avatar
voyager1
Cool !!! thanks !!!
Old Oct 30, 2007 | 06:39 AM
XXXRacing's Avatar
XXXRacing
Harley actually changed the module. I had the original on my night train which was just brake lights and turn signals. Then in 2006, they came out with the running lights\turn\brake light module.Now you can only get the latter. All kits use the same module, just make sure you are getting the module with the lenses for your bike. Great mod, highly recommended to all.
Old Oct 30, 2007 | 11:47 AM
bgismo20's Avatar
bgismo20
Best $50 I had ever spent! Very much needed for all!
Old Oct 30, 2007 | 12:06 PM
voyager1's Avatar
voyager1
ORIGINAL: bgismo20
Where did you find it for 50.00 ? even on line. i can not find one for 50.00 ?? Thanks for info .
Old Oct 30, 2007 | 05:24 PM
krub6t9's Avatar
krub6t9
Hey voyager check out the kuryakyn panacea lights. They are led and will get them as soon as possible. Did a lot of research in the forum and talked to the dealer.
best price i found them was at customdynamics.com do a search in the forums for this.
[IMG]local://upfiles/39516/1DCD91AED4914E6697AB7A3653ED06B2.jpg[/IMG]
Old Oct 30, 2007 | 05:48 PM
jrspringer06's Avatar
jrspringer06
54.95 at every dealer I have been to.
DGDyna
May 4, 2021 04:28 PM
EasyGT
Feb 3, 2015 02:55 PM
Cr1tter
Sep 22, 2012 09:59 PM
Dustmaker
Sep 1, 2008 12:26 PM
Cannon00000
Jun 17, 2007 03:36 PM
