Oil Change Tips
Old Dec 26, 2005 | 10:42 AM
dashiell's Avatar
dashiell
Default Oil Change Tips
Did my first oil change a t100 miles. First was a bitch when I removed the oil filter. I had rags stuffed under and around the filter but allot of oil still came out. and ran down the casing. Is there an easier way to remove the filter and capture the oil while funneling it to the catch pan.
Old Dec 26, 2005 | 11:02 AM
Thundercloud's Avatar
Thundercloud
Default RE: Oil Change Tips
JP Cycles sells a plastic trough type thing that latches under the filter so that when you remove it the oil drains down to drain pan.
I have used a heavy piece of cardboard and rolled it to fit under the filter and that worked ok. I have also just changed the filter and then spray everything down with Simple Green and then rinsed with water after a few minutes. Simple Green is great and non-corrosive so you don't have to worry about your chrome.
Old Dec 26, 2005 | 06:13 PM
Rhubarb's Avatar
Rhubarb
In a previous post, someone mentioned cutting a 2-liter soda bottle.
Put the wrench inside the bottle with your ratchet handle on the outside. and the bottle fills with the oil.
I haven't tried it yet, but it seemed like a great idea.
Old Dec 26, 2005 | 06:27 PM
MegaHDman's Avatar
MegaHDman
Yep, the cut 2 litre bottle idea works just fine. I do the same thing.
Old Dec 27, 2005 | 01:10 AM
sidewinder's Avatar
sidewinder
Call me stupid but I do not get it. If you cut the bottle and have the wrench inside the bottle and the ratchet outside, what keeps the oil from draining out where the ratchet handle goes in? I am presuming the handle goes through the cap hole?
Old Dec 27, 2005 | 01:22 AM
Rhubarb's Avatar
Rhubarb
Ratchet handle with extension through hole, filter wrench on inside.
Since the filter is horizontal, it shouldnt spill out, or least not too much.
Old Dec 27, 2005 | 01:49 AM
sidewinder's Avatar
sidewinder
What can I say, I am a little slow. Thanks for explaining further.
eviltwin415
Sep 25, 2017 11:55 PM
Timpechos
Jul 5, 2013 10:14 AM
dub976
Oct 3, 2010 10:09 AM
DGDyna
May 12, 2009 08:17 AM
bstrini
Oil Archive (no new posts)
Sep 7, 2007 11:33 AM
