Battery Tender Need More Knowledge
Old Dec 10, 2007 | 07:03 PM
Truckbizz's Avatar
Truckbizz
Account Deactivated
Default RE: Battery Tender Need More Knowledge
I've used a Battery Tender for a couple years as well and have never had any problems with it.
Old Dec 10, 2007 | 08:04 PM
ronyd's Avatar
ronyd
I have both HD and Battery Tender Plus. Both work well and no problems...
Old Dec 10, 2007 | 08:39 PM
rsavage's Avatar
rsavage
I don't have a battery tender, but I do have two battery chargers, one of which I periodically put on the bike in the garage on lowest charge (2 amps) overnight about once a month during the non-riding months. I have several batteries that I trickle during the winter from two boats, 66 C10, etc. Tenders like you bought are less labor because they are plug and forget. I don't mind the tinkering as I'm out in the garage (it's heated) evenings and weekends during the winter playing anyway. After Jan. 30 I can play full time as I will be retired. Its not even officially winter yet and I'm longing for spring. Sounds like your tender will work fine.
Old Dec 10, 2007 | 10:47 PM
Kevinc's Avatar
Kevinc
I have the HD tender it works great and it was priced right.
Old Dec 12, 2007 | 05:46 PM
Harley03joe's Avatar
Harley03joe
All Very Good Info Guys, And For That I Thank You All.
But My Question Was Not Answered
What I Need To Know If This Tender Is A Good One And The One I Need.
The Battery Tender Waterproof 12volt 800 Milliamp and 1.25 Amp,,
Thank You All
Harley03joe
Old Dec 12, 2007 | 07:17 PM
snakeinthegrass's Avatar
snakeinthegrass
I just bought the same one from Chicago HD and so far have had no issues with it. I attached the provided plug-in permanetly to the battery and routed the plug where it is basically out of sight but easy to plug in. I live in NW Louisiana and ride almost year around but sometimes we do have several weeks of bad weather where the chargermight be required.The waterproof feature is just added security against moisture getting into the unit. I have used it and it performs flawlessly. Hope that helps.
Old Dec 12, 2007 | 07:27 PM
glide's Avatar
glide
ORIGINAL: Harley03joe
I Just Got The Battery Tender Waterproof 12volt 800 Milliamp and 1.25 Amp,, Is This A Good One I Have No Idea.
I Am Useing It On My 2003 Softail Heritage Classis And My 2003 Sportster Hugger.
Any Help On If This Charger Is What I Need Will Be Helpful
Thank You
Harley03joe
Seems you have it already and now you are asking if it is a good one?
The smaller one is a better deal(.75) but yours will work fine. You can also switch it from bike to bike weekly to do both bikes with no problems. It's also best to draw some power from the bike periodiocally like with the lights on, and then recharge again. There will be more activity in the battery doing this and will keep the plates from sulfating. The small charge that the battery tenders put out isn't enough to do this. It just maintains the charge.
Old Dec 12, 2007 | 10:00 PM
vgfxst05's Avatar
vgfxst05
My battery tender came from my tool man at Matco tools. He comes to where i work every week. I am a cager tech for a Chrysler dealer
Old Dec 13, 2007 | 12:19 AM
Harley03joe
ORIGINAL: glide
Thank You
Harley03joe
Well I Can Always Take It Back, I Hope Asking Was Ok With You ?
I Want To Thank You And Other H-D Forum Readers, For All The Input
Harley03joe
Old Dec 13, 2007 | 12:22 AM
Harley03joe
ORIGINAL: snakeinthegrass
Thank You Snake, Good Info
Harley03joe [8D]
