HD Inverted Front End
Old Jul 5, 2008 | 09:32 AM
  #31
markthecelt's Avatar
markthecelt
Default RE: HD Inverted Front End
Anyone ever strapped one of these on a Fatboy? I am looking to replace the front end on my 07 fatboy with something more Softail Standard.
Old Jul 5, 2008 | 11:20 AM
  #32
brianp25's Avatar
brianp25
ORIGINAL: markthecelt
Hey Mark, I'm looking to do something with my front end also. i been wondering about the offset wheel though. If you change it out let me know how it goes, and how it rides. Thanks
Old Jul 5, 2008 | 11:57 AM
  #33
wtf6316's Avatar
wtf6316
DO IT. DO IT. Would look kick *** on your bike.
Old Jul 7, 2008 | 10:45 AM
  #34
Rocker C's Avatar
Rocker C
Turtle needs to visit China more often.
&nbsp\\;
Manufacturing in China is state of the art.&nbsp\\; Unlike many shops here in the United States that are still using broken down machines from the 1930's.
&nbsp\\;
Thats why Harley Davidson uses China for the bulk of its after market goods.&nbsp\\; It is unfortunate that the United States has not kept up with the times.
Old Aug 7, 2008 | 04:15 PM
  #35
markthecelt
Hi Brian..sorry for taking so long to respond, I have been away. You are correct to concern yourself with the offset, as near as I can figure. My thoughts are that we share a frame with the FXST so if I use wheels made for an FXST, front and rear for an 06' or 07'(aftermarket :-) ), I will net the same geopmetry as the FXST and be rid of that rediculous offset...make sense??? If the FXST has that offset and is masking it better than the Fatboy (I have never read this to be the case) same thing to me, my bike won't look like a freak sidewinder. Not sure if I will fo 18", 19" or 21" in the front yet....point is I will be spaced as an FXST, front and rear. I will go 17 X 210 on the rear.
Old Aug 8, 2008 | 08:27 AM
  #36
SuperAhcmed's Avatar
SuperAhcmed
Not sure what this "offset" issue is with certain year/model bikes, but I would think an offset issue can be taken care of with a spacer kit like the one Doherty Machine provides......
Old Aug 8, 2008 | 09:42 AM
  #37
FastHarley's Avatar
FastHarley
Former Sponsor
Please re-think everyones position of front wheel offset. What is the reason HD made the wheel offset in the fork? Do you think they (HD) did not know how to make the right size spacers to center the wheel in the fork?
Lets look at the wheel alignment than look at the weight from one side to the other. Your bike does not weigh the same on both sides from centerline. Next, why do you think that the new Softails have the wheels aligned in the front end? Do you think it might be that the frame neck in relationship to the rear tire might be offset in the newer bikes and when the 200 tire came out the frame & motor was mounted (dimension wise) differently? Maybe you could look at the different p/n's and see if the frames are interchangeable between years ie: where the front end/wheel is centered or not?
These are major components and once you start changing them you had better know what you are doing and the reasons why you can do it. If you wish to check this out for yourself pop on by and we can measure it for you. This is the equipment we have HERE than scroll to the bottom. You can learn first than do. Education saves on bad experiences. As far as spacers goes, what are you going to do with rotor/caliper alignment?
Old Aug 8, 2008 | 02:48 PM
  #38
captain m's Avatar
captain m
I don't mean to step into this chinese-American spat you guys are having,but I put H.D. inverted forks on my 07 fxstc and they're great!!! They perform good on bad roads.hang well in corners,they don't slam and bang like the Showa forks(if that's what Harley still uses) , and they look great.Everything fits to a tee and it goes together in no time at all.
Just follow the directions.
Old Aug 10, 2008 | 09:51 AM
  #39
markthecelt
Hey Captain, could you help me with the below (this is a paste from another post of mine)?
For the inverted forks, I would appreciate the measurement from the centre of the axle to the centre of the fender mount bolts and the distance between the inner forks where the fender mounts. As well, the measurement from under the top triple tree to the axle centre...thanks, really appreciate it!!!
Old Aug 10, 2008 | 10:09 AM
  #40
markthecelt
Hey FastHD, if you read my post carefully, you will see that I am suggesting we emulate the offset on the FXST on our fatboys using the parts from an FXST (wheels, spacers, forks, etc.)which have the same frame, motor and swingarms...this is not rocket science, we will net the same geometry as the FXST. We are maintaining a harley recipe in every regard.
Having said this, to blindly trust that HD does 'what is right' is a very bad premise. If I look at all the short comings on my 07' Fatboy that the MoCo produced for only 1 year before getting it right (or lets say, closer to right) in 08'. HDs haste to cram a 200mm tire onto a fatboy came at the cost of some really $hitty design, such as the rediculous offset and cowbells that scrape fenders which they fixed by carving out a piece in later models (and retrofitting early ones) and sticking a shim on to prevent the fork from travelling fully. Lets not even talk about the crappy new cranks that are so sloppy that HD chose to change the published tolerance (from .003" to .011") rather than fix the core problem...I question the integrity of the lousy bandages they produce rather than proper fixes..this is also a testimony to the quality of the engineering in the first place. I personally refuse to hang my hat on HD integrity or ability to design.
The MoCo is a corporation, as greedy as any example you will find out there, nothing more.
