How to attach exhaust baffle??
Old Dec 31, 2005 | 07:48 PM
dan789's Avatar
dan789
6th Gear
Default How to attach exhaust baffle??
I have a 2002 Softail Heritage with SE II slip-ons. The rivet that holds the baffle in one of the exhaust tubes is loose--rattles bad.
I tried reaching in with a big pair of channel locks to squash the rivet tight, but the rivet material is too hard for that.
What's the best way to reattach the baffle??
Old Dec 31, 2005 | 08:04 PM
Harley Al's Avatar
Harley Al
Default RE: How to attach exhaust baffle??
Drill out the rivet and intsall a new rivet
Hope it works for you
Old Dec 31, 2005 | 08:07 PM
Hog_fever's Avatar
Hog_fever
My SEII's use 2 bolts and nuts to hold in the baffle. I would either drill out the rivet or grind off the head with a dremmel and replace with a bolt. BTW, nice choice with the Heritage.
Old Dec 31, 2005 | 08:37 PM
HDF Tech's Avatar
HDF Tech
The newer SEII slip ons have a nut brazed to the baffle and use a bolt from the outside to fasten them in so they are removable.
Are these an older set?
Old Dec 31, 2005 | 08:49 PM
dan789's Avatar
dan789
6th Gear
These se II slip-ons were purchased new in 2002--not sure when manufactured.
I was thinking of using a nut and bolt, but was concerned about it coming loose. I figured that loctite wouldn't take the heat. I suppose a certain kind of locknut might work.
The existing rivet looks larger than the kind that would fit my pop-rivet tool.
Ratwerke
Sep 26, 2015 10:51 PM
tmitchellof PG
Exhaust System Topics
May 19, 2014 06:45 PM
cgmartine
Dec 3, 2012 05:37 PM
NICKNOAH
Mar 26, 2007 01:25 PM
jtfrog
11
Mar 12, 2005 04:08 AM
