Rear Axle Adjuster and Cover
Old Dec 13, 2007 | 10:27 AM
WaterHog's Avatar
WaterHog
Default Rear Axle Adjuster and Cover
Hello all.
I Just purchased the Rear Axle Adjuster and Cover Kit (43429-02) for my Deuce.
The direction states, that the Axle has to be removed, is this accurate?
It was seems to me, that I could installthe left side and then the right side, without removing the axle.
Thoughts??
BTW my exhaust system is already off.
Old Dec 13, 2007 | 10:47 AM
beaureed445's Avatar
beaureed445
Default RE: Rear Axle Adjuster and Cover
I'm not sure about how it works with the deuce, but with my '07 Softail Standard, the rear axle adjuster bolt had to come out.We didn't have to pull the entire axle. For the Standard, there are new bolts with the kit (which DO NOT fit between the axle and rear caliper). I had to re-use the factory bolts, instead of the shiny new chrome ones that came with the kit.
Old Dec 13, 2007 | 11:07 AM
WaterHog's Avatar
WaterHog
The adjuster boltwill come out with ease, but its the Castle Nut and the Axle Adjuster Collar that may give me trouble.
Old Dec 14, 2007 | 10:39 PM
Snarly's Avatar
Snarly
ORIGINAL: WaterHog
Check your email. I sent you a message.
Old Dec 15, 2007 | 07:07 AM
06DEUCE's Avatar
06DEUCE
i installed my axle from the other side. now when i need to remove my wheel or work on the rear i don't have to mess with the pipes. it affects nothing and saves labor...
Old Dec 15, 2007 | 06:45 PM
grumpy irish again's Avatar
grumpy irish again
yeh I do the same thing, the first time I took the rear wheel off w.t.f. so I ask at harley why and would it hurt anything "guess not as long as you torque it" well duh.................
Old Dec 17, 2007 | 10:57 AM
WaterHog's Avatar
WaterHog
thanks for the replies.
Old Dec 17, 2007 | 11:52 AM
FastHarley's Avatar
FastHarley
Former Sponsor
You multiple poston the same subject because you are Disillusion - 12/14/2007 9:23:51 PM (LINK) https://www.hdforums.com/m_2586024/m...tm.htm#2590588 and I spend time explaining in great detail how to do the job than you never even went back to the thread or even acknowledged the work myself and other members do to help you. What’s up with that? You are mad because in a few hours your "Technical" questions are not answered in a timely fashion? Are everyones time less importaint than your needs?
rocknrod
Mar 10, 2012 07:57 AM
basstracker05
Feb 1, 2009 11:42 PM
hammer72
Mar 9, 2008 02:04 PM
WaterHog
Dec 13, 2007 05:05 PM
wadejesu
Feb 22, 2007 07:04 AM
