vibrating headlight?
Old Dec 16, 2007 | 12:56 PM
MidnightFLHX11's Avatar
MidnightFLHX11
Default vibrating headlight?
hey guys, just a quick question. I noticed on my way home from pickin up my new scoot that the headlight seems to vibrate a lot more than my sportster one did. it seems quite a bit shaky. I noticed the same thing on a few bikes that I pass but never thought much of it, now i guess it's just a question to me of is it supposed to do that as a safety feature so its more noticeable or is something off? thanks in advance!
-copper
Old Dec 16, 2007 | 01:05 PM
HD7585's Avatar
HD7585
Default RE: vibrating headlight?
They might have it soft mounted with rubber bushings inside to reduce bulb failure. The old ones like mine are solid mounted
Old Dec 16, 2007 | 02:47 PM
rbabos's Avatar
rbabos
Three soft rubber mounts in there. If you want it more solid you will need to replace the rubber mounts with solid spacers. Personally, Ithinkit works as a safety feature and gets noticed more on the highway,so I'm leaving it the way it is. I don't ride all that much at night anyway. Too many critters.
Ron
jglasgow110's Avatar
jglasgow110
check out here https://www.hdforums.com/m_1386317/tm.htm. I had the same problem... 6 bucks at the local hardware store and it's rock solid.
Old Dec 16, 2007 | 03:11 PM
MidnightFLHX11
thanks a lot, im not sure if ill do it since i ride a lot at night and need the most attention i can get but it seems like an easy enough fix. thanks!
Old Dec 17, 2007 | 01:01 PM
WyndellF's Avatar
WyndellF
I tell people its the FXSTC headlight modulator doing its job
Old Dec 17, 2007 | 01:20 PM
Live2Ride's Avatar
Live2Ride
Banned Camp
It does get kinda annoying after a while. I was gonna leave it alone, but at some point, I'm gonna get it to where it doesn't shake. One thing I've noticed is that after a while, my headlight will wind up pointing at the ground so I can't see anything in front of me. I checked and it's mounted on there tight. It just shakes so much that it slowly moves itself down after a while.
Old Dec 17, 2007 | 01:44 PM
Mother's Avatar
Mother
Live2Ride,
I used to have the problem with it pointing down after a while too. Even with the nut and bolt tight as could be you could move it up and down without too much effort. I solved that problem by putting a 3/8" star washer on the inside of the bracket where the bolt goes through. It has stayed where I put it since I did that, probably three months ago. It should come like that from the factory. Just make sure you do it on the inside so it's between the inner bracket on the light and the outter that is on the triple clamp. If you just did it under the nut it wouldn't do anything.
Old Dec 17, 2007 | 01:48 PM
Live2Ride's Avatar
Live2Ride
Banned Camp
ORIGINAL: Mother
Live2Ride,
Thanks for the tip!
Jrsess
Jul 9, 2016 09:46 PM
Ozark Joe
EVO
Jun 29, 2016 11:23 AM
tke899
Oct 5, 2012 02:01 AM
tattoofever
Electrical/Lighting/Alarm
Jun 4, 2011 04:04 PM
Dawg Rider
Feb 19, 2011 09:04 PM
