FRONT SIGNAL LIGHTS
Old Dec 17, 2007 | 06:36 PM
tlb's Avatar
tlb
Default FRONT SIGNAL LIGHTS
I have decided I am going to move the front signals down to the forks on my Fatboy. I saw a post where a guy bought a chrome rod from Autozone. does anyone know the size of the lower bolt on the fatboy front cover/forks? and if any of you can find the post I am talking about it would be ncie.
Merry Christmas
Old Dec 17, 2007 | 08:21 PM
DR.Greenthumb's Avatar
DR.Greenthumb
Default RE: FRONT SIGNAL LIGHTS
This is how I did mine.Your turn signal housingand the lower fork bolt have the same size thread.Pull the fork bolt and match up some all thread or a bolt(if you get a bolt you'll have to cut it so it's only threads)at the Hardware store.You'll need at least an 1 1/2" of thread.Screw the thread into the fork so there'sa little more than1/2"left sticking out.Slip a chrome spacer over the threads.This needs to be at least 3/8" long.Take your turn signal and screw it onto the remaining exposed threads.You may have to mess with it a little to get the T/S housing to snug up to the spacer.I used blue loctite to make sure it wouldn't loosen up.I just cut the wires to theT/S prior toturning them on,then soldered them back after I had the signals tightened up.You really need a spacer inthere or you won't be able to tighten the housing all the way up.It will hit on the fork tins before it snugs up.
Old Dec 17, 2007 | 09:07 PM
tlb's Avatar
tlb
cool where di you get eh chrome spacer? I was just going to use a couple of chrome nuts from ACE Hareware
Old Dec 17, 2007 | 09:11 PM
DR.Greenthumb
I ordered mine thru JP Cycles.They had a packwith assorted sizes.Ace or True Value should have some too.
jram67
Feb 20, 2012 09:08 PM
Vinish
Aug 2, 2010 09:09 PM
SC-Longhair
Sep 7, 2008 10:40 AM
mfelsk
Aug 20, 2008 09:29 PM
WARG
Mar 29, 2007 04:22 PM
