Alternatives for front turn signals
Old Mar 27, 2007 | 07:50 PM
WARG's Avatar
WARG
Default Alternatives for front turn signals
Are there any other alternatives to relocating the front turn signals, besides mounting a light bar? I am not sure a light bar will fit with the overall look of my bike, but I would like to get the turn signals off the handlebars.
thanks
Old Mar 27, 2007 | 08:02 PM
ChicagoJ's Avatar
ChicagoJ
Default RE: Alternatives for front turn signals
Can go with a fork mount. Seen a few other posts on the subject before for how to do it. Looked good
Old Mar 27, 2007 | 08:51 PM
WARG's Avatar
WARG
I haven't found any fork mounts that will fit the Fatboy fork tubes, only the smaller front ends.
Old Mar 27, 2007 | 09:19 PM
DR.Greenthumb's Avatar
DR.Greenthumb
You can do them like this.It's easy.The lower bolt in your forks and the turn signal are the same size.Just screw a piece of all thread in the forks,put a chrome spacer on there and screw your turn signal on.Use some loctite.Solder your wires back together and you're good to go.
Old Mar 27, 2007 | 10:23 PM
loader's Avatar
loader
You got it - I used a 1.5" bolt and used a ratcheting wrench and torqued it from inside the turn signal housing.
Old Mar 27, 2007 | 10:26 PM
anubisss's Avatar
anubisss
I have mine mounted on the forks as well...
Old Mar 27, 2007 | 10:56 PM
kishstl's Avatar
kishstl
Can you do that with the detachable windshield set up?
Old Mar 27, 2007 | 10:58 PM
anubisss's Avatar
anubisss
Yes. My signals are where you attach the lower portion fo the quick detach windshield...
Old Mar 27, 2007 | 11:44 PM
WARG's Avatar
WARG
Great!!! A few questions...
What is all thread?
Loader can you repost the link for the image, it's not working?
Did you guys rout your wires behind the forks?
thanks
Old Mar 27, 2007 | 11:47 PM
Softtail Bob's Avatar
Softtail Bob
You could go with the mirrors that have the turn signals built in but it might be a PITA to run the wires inside the bars unless you were installing the bars at the same time. This is what I plan on doing when I get new bars.
