fuelpak or not???
Old Jan 25, 2008 | 06:15 PM
Modify's Avatar
Modify
Default RE: fuelpak or not???
I ran without the fuel pack and just pipes for amonthand it was ok alot of popping on decel. I changed the air cleaner and added the fuel pack and wish I had done it sooner. The bike runs so much better. Best thing would be to do it all at once or within a couple of weeks. I am glad I did not run my bike that way very long.
Old Jan 28, 2008 | 02:45 PM
Simatank's Avatar
Simatank
thats great to here i just ordered both a power commander (model III) and the Arlen ness big sucker so i should have them here and on the bike in a few weeks
Thanks again Guys
Old Jan 28, 2008 | 03:14 PM
Trotter's Avatar
Trotter
Fuel Pak ..... spend a little more and tune it right...
[IMG]local://upfiles/24219/ACA3DFE2F6504093A858F367DE72E8C4.jpg[/IMG]
Old Jan 28, 2008 | 03:28 PM
PoorBoy's Avatar
PoorBoy
ORIGINAL: Trotter
[sm=funnypostabove.gif] I guess we know your true feelings about the FuelPak; but didn't see a PCIII in the trash.
Are they O.K. (in your opinion) or do you prefer the SERT?
Just curious.
P.S. How about the TM w/autotune? (someday I want one of those).
[sm=icon_cheers.gif]
Old Jan 28, 2008 | 05:09 PM
1BadTrain's Avatar
1BadTrain
Ness Big Sucker and Fuel Pak......Runnin' like a ***** ****a!
Old Jan 28, 2008 | 05:14 PM
lh4x4's Avatar
lh4x4
I put the SE air breather on my 07 FXSTC with a Cobra F2000r. Kept the stock pipes but drilled a hole thru the shorty mufflers. Worked great. I could not believe the increase in power.[sm=happy046.gif][sm=biker.gif][sm=bounceybounce.gif][sm=bounceybounce.gif][sm=bounceybounce.gif][sm=bounceybounce.gif]
Old Jan 28, 2008 | 06:08 PM
Trotter's Avatar
Trotter
They may be OK for the V & H pipes but I never got it right with my setup.. I talked to them several times and they wont give any Info on what does what ... I thought the bikeran good but still got a little popping every now and then... WRONG... Bought the SERT and tuned it..Night & Day...
ThunderMax is a good unit...I've installed alot of them but never owned one.. I'll stick with what I Know.. DYNOJET 250I and SERT or PCIII..
I ran mine on the DYNO last week to set my A/F and I'll work on the rest later after I do my Cam's... Skip
[IMG]local://upfiles/24219/0AE34FCA37D6488A9FC196D7193C0305.jpg[/IMG]
Old Jan 28, 2008 | 06:30 PM
SoCalFattyBoy's Avatar
SoCalFattyBoy
Definitely do not go with the SERT!! Have had, and heard way too many horror stories. i wish that H-D would just do away with it... Jsut another way for them to suck the unknowing for their money.... The FuelPak is the way to go: Do it yourself and you dont have to deal with your dealer at all!! The FP is way too easy, save time, money, and headaches and go with the FP.
Old Jan 28, 2008 | 06:34 PM
SoCalFattyBoy
Must be another case of User error.........
Old Jan 28, 2008 | 06:48 PM
Josey Wales's Avatar
Josey Wales
Obviously you or the people you know that tune with the SERT do not know how to use it correctly! PCIII is very limited in tuning, if I had to do it over again I would go to a tuner that knows how to use a direct-link (cheaper than the SERT with same results) Had mine tuned with a SERT by a dealer that knows how to use both the SERT and Direct-Link with excellent results!
