HID Conversion
Old Feb 2, 2008 | 05:58 AM
firefly55's Avatar
firefly55
Default HID Conversion
Has anyone done an HID conversion to there Softail. I have a 2005 FLSTCI and cant figure out where to put the ballast. If anyone has done a conversionwhat did you fit and where the hell did you hide the ballast?
Old Feb 2, 2008 | 10:53 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default RE: HID Conversion
No problems. You can cut the wires & run them through the frame. The only thing you can not do is cut between the starter & bulb. the whole unit goes into the headlight bucket. They are very small. Hi & low on both in one light. You use your same plug that is on your headlight/plug for the hi/lo handlebar switch. an extra (+) must be run along with a ground (included in the harnass & harness extension. You nay need a 6' extension for an extra $11, that is your choice where you put the balast. The balast is very small & you can hide it under or behind your oil tanl ou under or between your gas tank. I put mine between the gas tank. Go [here]
Old Feb 2, 2008 | 12:52 PM
Gigawitz's Avatar
Gigawitz
I am waiting for mine to arrive, I planned on putting the ballast between the tanks also.
jcannady
Mar 22, 2017 08:09 AM
CopperHead2008
Mar 26, 2012 10:17 AM
ozsportster
Nov 20, 2007 01:36 AM
dlstanf2
Sep 13, 2007 07:36 AM
FastHarley
Jul 28, 2007 08:09 AM
