Crossbones Mod (Lic Plate moved to Axel)
Old Feb 11, 2008 | 08:38 PM
White Guy's Avatar
White Guy
Default Crossbones Mod (Lic Plate moved to Axel)
Hey guys. Just got my first real mod done. Moved my lic plate to the axel, and my buddy cut away the extra from my brake light housing. I'm real happy with the way it came out. Hope you like..
WG
Old Feb 11, 2008 | 08:39 PM
roadglidepa's Avatar
roadglidepa
Default RE: Crossbones Mod (Lic Plate moved to Axel)
Looks good - I have put the saddle bags on so this wont work but it really looks sharp.
Old Feb 11, 2008 | 09:23 PM
tchaffin's Avatar
tchaffin
That's the Road 6 Custom plate, right? Just ordered one of those off ebay. What was the fit, finish and install like? BTW, looks good!
-Tom
Old Feb 11, 2008 | 11:45 PM
White Guy's Avatar
White Guy
Well, the axel whole was undersized, so we had to dremel it bigger. The plate finish is a really nice powder black. I had to remove the washer to make it all fit right. Was pretty easy, and I couldn't be happier with the plate..
Old Feb 12, 2008 | 08:10 AM
ratatude's Avatar
ratatude
Hey WG ... That looks great. Do you have the lighted License plate bolts? How well do they illuminate your plate? What did you use to trim back around the lrear light?
ORIGINAL: White Guy
Old Feb 12, 2008 | 09:28 AM
White Guy's Avatar
White Guy
I did get the lumination bolts, but haven't wired them up yet. Honestly, I'm probably not going to. The light under the brake light is bright enough and lights up the rear tire and the plate. The whole tail light assembly is plastic, and my buddy used a jewelers saw to cut the extra out. Then we used a fine grit bit on our dremel to clean up the plastic hairs that were made with the saw, and fine tune the shape. After that I used extra fine sand paper, to smooth everything out. It was still a bit grey looking, so I used a permenant black marker and went over the cuts. You can not tell it's been cut now. It was actaully really easy. But, the saw really did do the trick.
WG
Old Feb 12, 2008 | 09:29 AM
White Guy's Avatar
White Guy
TC, yes it's the Road 6 Customs plate...
Old Feb 12, 2008 | 09:41 AM
psdj52's Avatar
psdj52
Looks good White Guy.
Old Feb 12, 2008 | 10:38 AM
Stevenacnj's Avatar
Stevenacnj
Nice job much better looking. I did the exact same thing to my FXSTSI.
Old Feb 12, 2008 | 10:57 AM
POKJWS's Avatar
POKJWS
ORIGINAL: White Guy
were did you purchase?
