First of all you need the 550's. The 551 is for spingers, and if you go with the 550 then us 1.5" risers. Wild 1 has them and they look great. Also if you change your risers from stock then you will need to go with a top calmp that fits the risers.
will the clutch, break line, and throttle cables need to be replaced if the 551's are installed on a Springer? does anyone have a link to pictures of a Springer with these installed?
