installing gimps on my bone?
Old Feb 28, 2008 | 04:08 PM
mojo76's Avatar
mojo76
Default installing gimps on my bone?
my 16" nash gimp hangers just came in for my crossbones. my question is how hard are they to install? (rewire, longer cables etc.). i've never worked on bikes before, but i am somewhat mechanically inclined. (i'm a plumber service and install boilers, water heaters etc.) i do have a service manual for guidance. are there any detailed walkthroughs on the web for additional assistance or should i just pay a pro to do it? i would really like to attempt this my self but on the same hand i don't want to screw anything up. any help would be greatly appreciated. thanks
[IMG]local://upfiles/34914/25FF72E5F7F24648B8B8BE019CDE87F3.jpg[/IMG]
Old Feb 28, 2008 | 05:24 PM
gorrilla's Avatar
gorrilla
Default RE: installing gimps on my bone?
is this set internally wired?
Old Feb 28, 2008 | 05:28 PM
gorrilla's Avatar
gorrilla
if so just take the factory plugs off the old wires put it on the new wires make sure you pay attention to the color code. you will probably need new idle and throttle cables and a new brake line. simple install . make sure you put a towel over your fuel tank when you do the removal. trust me youll thank me later
Old Feb 28, 2008 | 07:18 PM
mojo76's Avatar
mojo76
I will be doing internal wiring. do I buy new wire or splice together? I know i will need longer cables. again I appreciate all help. thanks
Old Feb 29, 2008 | 06:39 AM
DYNA JIM's Avatar
DYNA JIM
Can't provide much assistance on install, but can't wait to see pics!
Old Feb 29, 2008 | 10:52 AM
ndnhog's Avatar
ndnhog
j&p cycles and dennis kirk both sell wiring harness extensions so that you don't have to cut and spice your wires.
http://www.jpcycles.com/productgroup...ley&page=1
Here is a thread that helped me a ton with my install
https://www.hdforums.com/m_1328001/m...tm.htm#1328001
Old Feb 29, 2008 | 11:03 AM
DyNaBoB's Avatar
DyNaBoB
dont forget your tranny gasket and clutch cable oh and tranny fluid i use bel ray 80/ 90 hypoid gear
Ballsout
Jan 19, 2010 08:43 AM
07nightrider
May 28, 2009 11:08 PM
third_left_eye
Feb 18, 2008 08:14 PM
humpbackbob
Dec 23, 2007 05:30 PM
2StrongHayn
Oct 15, 2007 10:26 PM
