05 Fatboy ECU Relocation
Old Mar 16, 2008 | 05:12 PM
kdisrude's Avatar
kdisrude
1st Gear
Default RE: 05 Fatboy ECU Relocation
Just finished up today with all else I am working on, and finally at the last few items. Did you have to make the wires longer for the connector to reach the ECM where the alarms go? It is just out of reach for it to connect...
Thanks!
Old Mar 16, 2008 | 05:36 PM
tk353's Avatar
tk353
No problem, the wires were long enough if you run it between the relays. There was a gap between the 2nd and third relay. You also need to run the connector under the wire harness that is at the bottom of the relays
Old Jan 22, 2013 | 12:47 PM
reefonline's Avatar
reefonline
Default ECM relocation
I relocated it to a box in my shed and put a carburator on the bike instead... works so much better!
ronshfd
Softail Parts
Jun 25, 2017 09:57 AM
bigpete1
Softail Parts
Aug 8, 2015 11:29 AM
fatboy981
Aug 28, 2007 08:53 PM
elcid1989
Jul 23, 2007 02:22 PM
Gjerb
Jul 3, 2007 07:47 AM
