Flush mounted turn signals?
Old Mar 13, 2008 | 11:49 PM
Stretchman's Avatar
Stretchman
Default Flush mounted turn signals?
Back in the late 90s, there were some flush mounted turn signals, and I can't remember who makes them. They had chrome housings, and ramped out from the sideplates, then there was a small light, and they sloped back in toward the frame at the rear. Does anyone have any idea what I am talking about? I'd love to figure out who made them, and I want to get a pair for the softie.
Old Mar 13, 2008 | 11:55 PM
darkman's Avatar
darkman
Default RE: Flush mounted turn signals?
Arlen Ness, or Drag Specialities! A good choice.
Old Mar 14, 2008 | 12:32 AM
J's Avatar
J
Kuryaken made them. I think they still do... check J&P cycles.
Old Mar 14, 2008 | 07:34 AM
Sarge4life's Avatar
Sarge4life
Are these what you are looking for? http://www.jpcycles.com/productgroup...D-837CAAEF43C7
Old Mar 14, 2008 | 08:09 AM
Biminitwist's Avatar
Biminitwist
Check out Alloy Art they blend into your struts look great and easy to install.
Old Mar 14, 2008 | 03:04 PM
Stretchman's Avatar
Stretchman
They look a lot like them. After looking at the signals tho, I think that they wouldn't fit because of the sissy bar struts. I am wondering if there is on like those that will work on that part of the strut. I appreciate the help though. I always liked the fact that they didn't stick out, but were still very visible. Maybe LED type, when I can get to them. I certainly blew out my bike budget this month already. Next month is looking better. Pricier than I originally thought. At Arlen Ness, http://shop.arlenness.com/store/prod...roduct_ID+7052they have the red for the rear and they are available in LED; I don't know if they'll fit. I also don't see the ones they have for the front anywhere yet. If anyone comes up with anything, please add it, and if I find anything, I will.
These might work if they made them in red.
http://www.dragspecialties.com/fatbook/17/353/5912645
Old Mar 14, 2008 | 08:19 PM
tmitchellof PG's Avatar
tmitchellof PG
The ones I installedmount flush to the struts. I neededroom for the saddlebags.
Tom
[IMG]local://upfiles/18321/2CB74582BDD74AFDBCA8F192044317F8.jpg[/IMG]
Old Mar 15, 2008 | 06:09 PM
ajl10spro's Avatar
ajl10spro
6th Gear
tmitchell where did you get yours
Old Mar 15, 2008 | 08:40 PM
vertigo14's Avatar
vertigo14
I have the same as tmitchell, in fact he helped me with finding them
Strut mounted LEDs
Old Mar 15, 2008 | 09:02 PM
tmitchellof PG
ORIGINAL: ajl10spro
I ordered them from the J&P catalog. They are on page 372 of the current catalog. You can look at the catalog on line if you don't have one. They are from Kuryakyn and are called LED strut mount mini bullets. Part number 330-641 for the red lens and 330-642 for the amber. They cost $79.99.
Which ever lens color you order, they will come with the clear lens installed and have the colored lens separate in the package. Make sure you change the lens, to the color you want,before you install the signals. If you install the signals first, you will find out that the set screw that holds the lens in place is trapped against the strut. This means you have to take the struts most of the way off to access the set screw. I sent an e-mail to Kuryakyn to let them know what I though of the moron that placed the set screw in that location, but I doubt if they have changed the design.
Other then that they work fine and nest nicely against the struts.
Tom
08streetbobbin
Mar 21, 2014 04:48 PM
Bigdaddy89
Shovelhead
16
Oct 2, 2012 04:12 PM
section8joe
Aug 1, 2011 07:09 PM
CKS
Mar 15, 2011 09:15 AM
ScooterGuitar
Apr 23, 2005 02:33 AM
