Performance upgrades?
Old Apr 2, 2008 | 03:32 PM
WARG's Avatar
WARG
Default Performance upgrades?
I am saving up for a D&D Fat Cat. I will also add the K&N filter at that time as well. I figured I may aswell do some new cams or something if I am paying for a new dyno tune anyway.
Current set up: PCIII, SE A/C, Porker Hatchet Pipes
Planned Mods: D&D Fat Cat, K&N Filter, ????
I don't want to spend aboat load. I have looked at Big Bore Kits like GMR Performances 98" kit and the Screamin Eagle 95" kit, but don't really want to spend $3-$4K, on top of the cost of the Fat Cat.
I was thinking just a set of cams, oris this even worth my while?
Please make some reccomendations, or should I just wait and doit all at once (big bore kit w/ cams, etc.)
Old Apr 2, 2008 | 04:17 PM
darkman's Avatar
darkman
Default RE: Performance upgrades?
If you are going to dyno it n can get the cams then do it!!!! A little extra cost
Old Apr 2, 2008 | 04:26 PM
Waltman's Avatar
Waltman
ORIGINAL: WARG
You can do whatever you want, but to answeryour question, and from what others have posted in this site, the gains are puny. If your expectations are big might as well rethink. I'd just whack open that throttle
Old Apr 7, 2008 | 11:23 AM
gum's Avatar
gum
There is little benefit from just doing the cams and the labourcost is high. If you're not ready to get a bigger bore stick with the Stage 1 upgrade and save for Stage 2 cams and larger bore and get it all done at once. When you make that change you will never regret it.
Superglide2012
Jul 9, 2014 12:19 PM
07bobber
May 19, 2014 09:14 PM
skjskmata
Aug 22, 2011 09:59 AM
hdokie
Sep 6, 2009 10:43 PM
magnoliarunner
Oct 27, 2007 10:50 AM
