Relocate turn signals for Rocker.
Old Apr 9, 2008 | 12:08 PM
DawgHamilton's Avatar
DawgHamilton
Default Relocate turn signals for Rocker.
A few have asked so here it is... V-Rod 49mm Fork Mount turn signal relocation kit. Cost is about $50. Other then the turn signals I have '07 VH Big Radius, EFI Race Tuner, SE Heavy Breather... Great sound and runs real nice. A little decel popping which I will have checked my next stop in.
DH
Old Apr 9, 2008 | 12:20 PM
gadawgsfan's Avatar
gadawgsfan
Default RE: Relocate turn signals for Rocker.
dawg, is that an exact fit or did you have to make any mods to the bike or to the mounting brackets, also would you happen to have the part number
Old Apr 9, 2008 | 01:27 PM
DawgHamilton
Sorry I forgot the specs... Kuryakyn Accessories Part #: 2287 - KURYAKYN 2-PIECE 49MM FORK MOUNTS PAIR.
Old Apr 9, 2008 | 01:32 PM
DawgHamilton
ORIGINAL: gadawgsfan
Bolt on, no mods.
Old Apr 9, 2008 | 01:41 PM
RockerMike's Avatar
RockerMike
Looks great! How about the wires. How did your run them? Can't see them in the pic, how do they look from the back side?
Old Apr 9, 2008 | 01:55 PM
DawgHamilton
Here are a couple pics. Also when you relocate you will have the threaded nuts still on your bars. Onnthe right side remove the double threaded nut and just buy a standard mirror acorn nut to replace. The other side is offset with a plate that has the threaded nut attached. Remove the left mirror acorn and take off the spacer plate and replace with a washer. Let me know how it turns out.
Old Apr 9, 2008 | 02:34 PM
RockerMike's Avatar
RockerMike
That looks pretty good. Thanks for the pics.
Old Apr 9, 2008 | 02:40 PM
emsley3's Avatar
emsley3
Do you know if those will interfere with the Fork Bag? I want to move the signals but don't think I want to give up the one place for storage on the bike even those it's a small amount.
Old Apr 9, 2008 | 03:08 PM
MartyF's Avatar
MartyF
I'm thinking about using the Heartland turn signal mirrors.
Old Apr 17, 2008 | 02:42 PM
flyburch's Avatar
flyburch
ORIGINAL: MartyF
now that is a great idea
