hey, atleast you have good spelling for being tired, mines goes out the window.. yes all you need is the 4886 then for the rear,and a few chrome bolts from the hardware store to fill the holes in your fender struts after you remove the old stock signals, and you doog to go. On the front I relocated my signals to under my headlight inbetween the forks and went with a led bullet, keep in mind when you goto led in the front you will need a load equalizer to be added in line.
thanks, I just relocated my front signals to my forks so I will leave them there for a while at least. I still think removing the rear signals will look sick. I just ordered some chrome controls so the taillight will go on the list. I may go with the smoked version though.
I have the full set on my Roadglide except I have the blue dot. You can see them fine in the daylight. Mine have been on for about 2 1/2 years now. I love them.
What is the difference in the regular Panacea and the Panacea Blue Dot?
the blue dot has 3 or 4 blue dots in the center of the chrome ring.
they attract a little extra attention and are actually a little annoying to drivers behind you.
see here for pix http://www.customdynamics.com/harley...al_panacea.htm
