07 fxstc fuelpack
Old Apr 30, 2008 | 12:44 PM
gazzer's Avatar
gazzer
Default 07 fxstc fuelpack
Hi, anyone recalibrated a fuelpack on an 07 softail custom. My map supplied by v&h is FP-1455. Any advice out there would be appreciated
Old Apr 30, 2008 | 12:48 PM
NightTrain08's Avatar
NightTrain08
Default RE: 07 fxstc fuelpack
depends on what you want it to do and any issues you are having, I can but need to know what is wrong first.
Old Apr 30, 2008 | 01:51 PM
gazzer's Avatar
gazzer
Bike is running fine and crisp but I get popping like its lean but not till revs drop down just off idle.If I give the bike a good thrashing I get no popping at all.Am I being fussy?
Old Apr 30, 2008 | 02:13 PM
NightTrain08
no it is not lean, it is rich on the bottom end. You have made no changes to the map 1455 you are using right? If you have made no changes at all, change these and see how it works. I put the original values to the right so you can see.
Mode 1 should be a 1 - original map is a 3
Mode 2 should be a 2 - original map is a 4
Mode 17 should be a 2 - original map is a 0
Mode 23 should be a 15 - original map is a 16
Old Apr 30, 2008 | 02:35 PM
gazzer's Avatar
gazzer
Thanks I"ll try the mode changes tommorow.
Old Apr 30, 2008 | 03:59 PM
AK47's Avatar
AK47
All my problems went away after changing mode 23 from 16 to 15. Good luck.
gwk
Aug 14, 2015 11:17 PM
Koppster
Jan 10, 2008 04:30 PM
Mr5150
May 6, 2007 04:20 PM
BadBobOk
Apr 27, 2007 12:04 PM
BadBobOk
Apr 27, 2007 09:40 AM
