Rocker Questions?
are the handle bars moveable? i know they are individual bars, can they be rotated in the risers? when i test rode one the bars were pretty low, i like them up higher (rotated forward). if not, looks like i will be getting the drag bars until i can find something else
do any of you have the siren with the security? if so, did you install it? was it hard? the dealer where my bike is coming from says that is much harder to install on the rocker than any other softail. they want to charge 2 hr labor!! I am pretty mechanically inclined and figure I could do this myself.
any thoughts?
thanks
I also installed a siren. I went the Radio Shack route for $6. Not many features, but makes noise. There is a previous post that shows step-by-step how to install on a Night Train. Everthing is the same except I removed the rear fender to make access easier. Just remove the 4 bolts, really easy. Then remove the plastic cover ( 3 allen screws). Everything else looks just like the pictures in the post. I am not sure, but the HD siren is probably a plug in. Total time 45 minutes tops.
Here is the link
Radio Shack Siren On an 07 Night Train!!! -HOW TO- [/align]
After removing the rear fender and plastic cover you'll see a plug with nothing attached in the upper right hand corner. Thisplug plugs into theH-D Siren and the siren snaps into the holder that H-D has provided on the right side.
I have done both to my Rocker C. The handle bars do rotate in the risers. Just loosen 4 mounting bolts.
Here is the link
Here is the link
