i want to run straight bars on my rocker any suggetions? with the stock bars i feel cramped. anyone know what riser and bar i can use? and where to get them cheap? ok its a harley not much is cheap. i was going to buy some used bars at valentines day massacre for $15. but didnt know if they would work.
Just get the Harley drag bars that are made for them. I had mine put on before I took delivery and I love them. I came from a Night Train, so I'm used to the straight bars. It's easier going that route then getting new risers along with bars.
i want my bars about 1"-2" lower than yours and about 1"-1"1/2" farther forward. i think its hard to tell without trying them but dont want to waste money on bars im not going to use.
Well the factory riser is 8 inches, so you'll want a 6-7 inch riser then. If you go with a straight-up riser, not a bent riser, you'll be about 2 inches forward from stock. So you should be able to accomplish what you want to do if you go that route.
tom where did you get those? you have a tank lift in that pic? im thinking about the tank lift but not sure about yet. im saveing for badland digital mirrors so i can either shave my tank or switch to a different tank.
They are Carlini Original T-Bars...with a 9" rise and 7.5" pullback....I also added a Novello 1.5" riser to make them total bar rise 10.5". I do have a 2" tank lift on it. Carlini makes the same bars with less rise if you want them lower...oh the bars are 1.5" diameter http://www.carlinidesign.com/handleb...bars/index.php
Try The Handlebar Company website
I have their Flat and Wide 1-1/4" bars with 142 5" pull back risers
This has changed my Rocker for the better more than I had hoped for - a much better ride plus a better look
Would never never go back to the Rocker bars
Mort
