Fuel Map
Old May 9, 2008 | 08:32 PM
Nroman's Avatar
Nroman
2nd Gear
Default Fuel Map
Does anyone have a PC III fuel map that is working well with Vance & Hines Softail Duals,an Arlen Ness Big Sucker A/C and a PC III usb onan otherwise stock 2006 Softail? I experience popping on decel, and higher than normal operating temps. My PC III map from Fuel Moto seems to need tweaking. I have tried adding 10's to the zero column from 1750 to 5000 RPM, but that hasn't cured the popping. Thanks for any help!
Old May 9, 2008 | 10:12 PM
20FXST06's Avatar
20FXST06
Default RE: Fuel Map
Nroman, Go to the Power Commander web site, email the tech dept. tell them you problem, they will tell you which map to use. If you have a problem with the map they will help you fine tune with adjustments. They have great tech staff and are more than willing to help. I had the same situation with the popping. Bike runs great now.
Old May 10, 2008 | 01:15 AM
tk353's Avatar
tk353
Get a dyno tune done. You wont believe the difference over a canned map.
Old May 13, 2008 | 10:36 AM
Nroman's Avatar
Nroman
2nd Gear
Thanks for the help guys. I think I'll go with a different canned map first, try to tweak with them and if that doesn't work, I already have an appointment at the dealer to do some other work, and will have them dyno it.
Road Star
Sep 25, 2013 09:10 AM
FIDDY3
Mar 24, 2010 09:04 PM
shagnasty
Mar 11, 2009 04:16 PM
AdrianVall
Exhaust System Topics
Aug 29, 2008 12:02 PM
Dogs of war
Feb 9, 2007 10:01 AM
