I've never done this on a bike before but I have done enough cars to feel confident. Every post I searched said it was about a 15-30 minute job, I hope they're right. I keep reading about those Lyndall Z Gold pads. Are they compatable with existing/stock rotors? Are they noticably better than standard Harley's?
I run EBC's so I can't say about the Lyndal's.
When I changed the rear pads on my Standard, the book said to remove the pad pins and pull them out enough to change the inner pad, pump the brakes back up then pull the pins and replace the outer ones. \\; I found it easier to just pull the pins and do both pads at once.
You'll need a 1/4" 12 point socket or end wrench to remove the pad pins.
Here is a link on how to replace them. Very easy if you have the correct parts. I have a new pair of fa400 i want to get ride of. http://fatbillscustoms.com/
Looking at Lyndalls website, it appears the gold will work with stock rotors. I used the Z-Plus and they stop WAY better than the stock pads. No dust and the scuffing on my rotors smooth out some.
