How do you remove the spash guard ?
Old Jun 9, 2008 | 07:51 PM
sfrisby6022's Avatar
sfrisby6022
Default How do you remove the spash guard ?
I have an 08 Deluxe - and will be installing the security siren - looks straight forward ... but I can't seem the two bolts to take off the splash guard.
Any assistance appreciated.
Old Jun 9, 2008 | 08:07 PM
Django696's Avatar
Django696
Default RE: How do you remove the spash guard ?
just remove two bolts from the bottom,and lift it up, to get tab out of slot.. you may have to wiglle it around to clear the tire and frame.. If bolts are not coming out pull guard away as you loosen them...
Old Jun 9, 2008 | 08:15 PM
markymark02's Avatar
markymark02
I'm not positive, but if it's the same as the Fatboy the 2 bolts are facing the rear tire, if you put the bike it'll be easier to work on, but if you feel along the bottom&nbsp\\; of the splash guard they should be about an inch or two from the bottom, hope that helps you out.
Old Jun 9, 2008 | 08:57 PM
tk353's Avatar
tk353
should be the same as my 07 Fatboy. 2 bolts and then just drop it down. you should have room without removing the splash guard
The Spook
Jul 7, 2012 04:22 AM
pauletich
Dec 18, 2010 06:58 AM
JoeEMT
Jul 2, 2010 05:30 AM
congo_usmc
Aug 4, 2009 07:18 PM
Basil
Sep 20, 2007 04:58 PM
