O2 IED vs XiED
 \\;I know this is splitting hairs, but shouldn't it add some HP.
 \\;Most say that they sound (exhaust is louder due to more combustion pressure, a/f being added) \\;better and feel that they can cruise better (with less effort) since using XIED's. I would think that means they must have \\; a slight bit more hp to do so.
 \\; I had only asked if anyone had ever dynoed this result.
 \\;As for codes, the ecm thinks it is lean with the XIED's installed and kick the codes out (131/151) than richen the fuel mix. \\; But all along it still thinks it is lean.
 \\;I don't think it causes any harm to have the codes. A more knowledgeable person would need to \\;address that area.
 \\; Just my $.02
 \\; Just my $.02
The only way to find out how much is to dyno the bike without and then again with the X's
Now a question for you guys in the know as far as the resistors are concerned.
I am in the UK and getting stuff over here from the US is a pain in the a$$ due to our import taxes.
So can anyone help me out with the size of resistor that is nesissery to do this mod myself and try and get the ratio to as close to 13.0 as i can.
I might add this is for a new XR1200 Sporty i have bought over here in the UK a month or two back.
As far as i know it has the same set up as the big twins when it comes to the EFI set up, i have already fitted a pair of supertrapp universal mufflers and want to cool the motor down a touch.
Had HD's for 23 years, all big twins (also got a 2000 carburated softail) but this is my first injected HD.
Thanks in advance.
I built my own IEDs. Can;t say that the heat really decreased significantly. But, my throttle response is definitely noticeable. I basically have stock bike with just a K&N 3909 A/C..
BTW, I built these for the fun of it, and not to save money!! Allows you to get to know your scoot doing this stuff....
But thanks for your time.
Thats half the fun for me, playing with stuff, never used a dyno in my life, and had all the fun in the world doin it by my seat of the pants dyno
