help needed with bleeding brakes!
Old Jul 1, 2008 | 03:00 PM
hogster1961's Avatar
hogster1961
Default help needed with bleeding brakes!
Recently fitted a set of Ness forward control extensions to my 07 Night train and just can't get a good rear brake,I've bled it countless times using every method I know,even bought one of those vacuum pump gadgets but still no luck,get a good solid feeling brake in the garage but 100 yds up the road it's weak as a kitten with loads of play on the pedal,comes up a little if I pump it which would suggest air is still in the system but when I get back home and re-bleed....nothing just clear fluid.
Only weak spot I can think of is the brake pressure switch block,&nbsp\\;either faulty or I have it mounted the wrong way round,does anyone know if there some kind of one-way valve in the switch block&nbsp\\;that could cause this issue? Kit didn't have instructions so I just mounted it the only way it would seem logical,line from master cylinder comes in from the front,switch above that facing right as you&nbsp\\;look at the bike&nbsp\\;and line to the calliper exits at the top over the swing arm pivot to the calliper....does that all sound ok?....Please help me out guys I love the new riding position but can't ride without a rear anchor!
harley7316
Sep 18, 2014 12:15 PM
Josowski
Wheels/Tires
Aug 4, 2012 07:06 AM
83ShovelheadLowrider
Wheels/Tires
Aug 31, 2010 05:55 PM
bfgoodmudder
Apr 16, 2010 12:48 AM
fastjoe
EVO
Jan 19, 2010 08:37 AM
