Crossbones Owners...questions
Old Jul 9, 2008 | 09:56 PM
tnharley7's Avatar
tnharley7
Default RE: Crossbones Owners...questions
The correct Owners Manual is 99469-08A.&nbsp\\; The correct Service Manual is 99482-08A. The owners manual is clear that the Springer requires maintenance at 500 miles.&nbsp\\; I had the dealer perform the first service at 500 miles on the XBones since I did not have the manual yet and didn't have a clear understanding of the Spring front end service.&nbsp\\; What is required is adjustment of the lower rocker bearing which requires the front fender and tire to be removed.&nbsp\\; Then the lower rocker bearing is torqued and verified to not exceed a certain value of torque to rotate it thru a 180 degree arc.&nbsp\\;Then reassemble everything.&nbsp\\; Also the head is filled with grease since the factory only lubes the bearing and does not fill the head.&nbsp\\; The fall out is also checked and the head bearings adjusted if required.&nbsp\\; If you don't have the right tools the lower rocker bearing would be difficult to do.&nbsp\\; I have asked on several HD Tech groups and HD techs online all highly recommend at least having the lower rocker bearing adjusted at the 500 miles.&nbsp\\;
Old Jul 9, 2008 | 09:57 PM
Ole Coyote's Avatar
Ole Coyote
ITS THE SOFTAIL MODELS MANUAL 99469-08A.&nbsp\\; ITS THE ONE I GOT WITH THE BIKE
Old Jul 10, 2008 | 04:10 AM
bfreesun's Avatar
bfreesun
According to my dealer all springers need a 500 mile first service.
Nothing in my manual about the Cross Bones and dealers (2) know little.
ORIGINAL: Ole Coyote
Page 154 for seat removal.
I just had a 1000 mile service awhile back and the service mechanic looked all over and asked if it felt OK and that was it. \\\\\\; I think the 500 mile service it a rumor. \\\\\\; As long as nothings falling off and it feels good, what the hell just ride it.
Old Jul 10, 2008 | 08:37 AM
xkvator's Avatar
xkvator
Thanks for the part #'s/info on the springer service...
&nbsp\\;
stopped at the dealer yesterday, to show them the Brawler seat i put on...and the HD parts computer doesn't even have FLSTSB&nbsp\\;in it...
SOA
Jun 28, 2017 06:20 PM
GymRat523
Jun 14, 2009 07:21 AM
chilango13
Oil Archive (no new posts)
Sep 7, 2006 12:20 PM
Optical
Aug 25, 2006 10:22 AM
FloridaRider
Jan 22, 2006 10:25 PM
