Rocker turn signal relocation...
Old Jul 30, 2008 | 11:56 AM
RockerDave's Avatar
RockerDave
Default Rocker turn signal relocation...
Does anyone have the part# for the turn signal
relocation brackets for the Rocker? I had seen them
elsewhere on the forum, but I cant seem to find them
again.
Thanks
Old Jul 30, 2008 | 01:16 PM
jipmkwa's Avatar
jipmkwa
Default RE: Rocker turn signal relocation...
+1 looking for this also !
Old Jul 30, 2008 | 01:38 PM
kylant's Avatar
kylant
i have tried 2 different kits, neither would work.
i think the only ones that will work are the kuryakyn ones for the 49 mm forks or the custom cycle engineering ones 2020-0303 from drag specialties. i am going to try either one of these, but first i might try the smaller brackets made by hd, 68266-03. they may give me enough room to clear when i install the tank lift
Old Jul 30, 2008 | 02:08 PM
RockerMike's Avatar
RockerMike
Try this link https://www.hdforums.com/m_3180025/tm.htm
Old Jul 30, 2008 | 07:28 PM
firerocker's Avatar
firerocker
5th Gear
the 49mm ones for the v rod will work, thats the ones i used....
Old Jul 31, 2008 | 08:51 AM
kylant's Avatar
kylant
ORIGINAL: firerocker
Not the ones from HD. I tried. the ones from kuryakyn will work though.
so far there are two brackets that will work, the ones posted above.
i am going to get the shorter bracket today and see if it will give me enough clearance for the tank lift
Old Aug 4, 2008 | 09:10 AM
kylant's Avatar
kylant
i just used the kuryakyn ones. mounted just below the top tree. i will post pics later
Old Aug 4, 2008 | 03:43 PM
MartyF's Avatar
MartyF
Just a thought. I'm using turn signal mirrors in place of the stock turn signals on the bars.
Old Aug 4, 2008 | 03:55 PM
gadawgsfan's Avatar
gadawgsfan
the problem with these kits is there is no place to hide the wires and leaves to much of the wire exposed, imo
Old Aug 4, 2008 | 06:51 PM
hispeed's Avatar
hispeed
This is the Kuryakyn kit #2287. I just replaced the 5/16 x 18 thread bolts with a 1" x 5/16 x 24 thread bolt and it works perfect with the stock signals.&nbsp\\;It does leave a lot of wire exposed but the looks are so much better regardless of the wires. I just had to grind the bolt head down to fit inside the clamp so it wouldn't rub the fork tube.&nbsp\\;You can be more picky and find a rounded bolt head that doesn't require grinding but I just wasn't that worried about something that will never be seen.
&nbsp\\;
Good luck, I've attached a pick of my install.
