Oil draining?
Old Mar 15, 2006 | 07:43 PM
ken05's Avatar
ken05
Default Oil draining?
whats that plastic part that screws on to the motor like an oil filter with a hose attachment to drain oil.
Old Mar 15, 2006 | 11:03 PM
Unibomber's Avatar
Unibomber
Default RE: Oil draining?
Are you talking about scavenger ?
http://www.roguechopper.com/
Old Mar 16, 2006 | 02:17 AM
ken05's Avatar
ken05
Thanks
Unibomber thats what i was looking for.
Old Mar 16, 2006 | 04:30 PM
ajay450's Avatar
ajay450
What's required to do this? Some kind of special equipment.
Old Mar 16, 2006 | 04:38 PM
HDF Tech's Avatar
HDF Tech
For you guys with the softails ( AJ ), you're in luck... https://www.hdforums.com/m_254963/tm.htm
Check out the other topics in the DIY area... https://www.hdforums.com/forumid_241/tt.htm
Old Mar 16, 2006 | 04:42 PM
ajay450's Avatar
ajay450
OK. I watched the Scavenger video.
went_postal's Avatar
went_postal
I'm guessing that you drain the oil, take off the oil filter, refill the oil tank, put the scavenger on, start the bike, run till clean comes out, stop the bike, remove scavenger, install new filter, and top off oil tank?
Sounds/looks easier than some of the DIY stuff that I have seen where people remove oil lines and whatnot...
Old Mar 16, 2006 | 04:50 PM
ajay450's Avatar
ajay450
You need the quick disconnect tool to remove the fitting at the end of the return oil line so you can get the plastic tube over the end? I that the deal?
Old Mar 16, 2006 | 05:04 PM
Babs's Avatar
Babs
Words from Experience..
And remember one thing.. make sure when you attach a hose to the return line, that it's on TIGHT!
Smooth-Move here managed to pull a less than admirable job of spraying nasty oil all over the side of my scoot and pant legs when the hose popped off.
If you were there, you would have cracked a rib laughing at my sorry a#$!
I was less than amused though but thinking about it, if it weren't me that did it, I would have been in the floor crying in sheer uncontrollable laughter.[sm=icon_rofl.gif]
Bluraven
Sep 12, 2021 04:18 PM
cajun1957a
Sep 10, 2016 08:35 AM
boro
Sep 5, 2014 03:35 PM
Hamperdiver
Oct 22, 2007 11:53 PM
