Do I need metric tools?
Old Aug 20, 2008 | 06:29 AM
Sono54's Avatar
Sono54
Stage III
Talking Do I need metric tools?
Harley newbie (2006 Heritage Classic). Is there any reason to carry metric tools in my tool kit?
Old Aug 20, 2008 | 07:48 AM
ratatude's Avatar
ratatude
Yeah ... Too fix the broken down crouch rockets you come across...
Old Aug 20, 2008 | 08:38 AM
128auto's Avatar
128auto
The only metric wrenches you need on your bike will be brake caliper and carburetor, other than that, you will be fine. Bring an adjustable wrench, you have both world lol.
Old Aug 20, 2008 | 09:18 AM
oldgeezer's Avatar
oldgeezer
128auto is right. The brake caliper is a #10 12 point (if I remember correctly) while the pad pins are 1/4" 12 point. Kinda wierd to me. Also, check your battery connections, they are probaby #10 metric. If so, I'd throw in a #10 end wrench that's 12 point. Haven't run across anything else.
Old Aug 20, 2008 | 09:26 AM
Bluesssman's Avatar
Bluesssman
Battery terminals are 10 mm. Check your manual it tells what metric bolts you have.
Old Aug 20, 2008 | 09:33 AM
Other Sheep's Avatar
Other Sheep
Bring a small left hand metric adjustable and you'll be fine.
Old Aug 20, 2008 | 10:07 AM
Sono54's Avatar
Sono54
Stage III
Thanks. I'll leave out the metric Torx and metric allens. The tool kit was getting kinda heavy.
Old Aug 20, 2008 | 10:41 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
For a road kit the only metric I would bother with is the 10mm for the battery. Anything more involved that that, like brake parts, leave the tools at home for when you have the time and space to work on it properly.
Fortunately even if you do have a serious problem with the brakes. Bikes have two independent systems so a problem with one won't affect the other and you should still be able to get home. You just need to plan your stops sooner/better and make damn sure you keep your distance from the 18 wheeler or cager riding his brake pedal in front of you.
Old Aug 20, 2008 | 10:43 AM
128auto's Avatar
128auto
Make sure you have a 5/8 wrench to tighten up the rear sprocket bolts.
Old Aug 20, 2008 | 12:35 PM
vertigo14's Avatar
vertigo14
there are several more metric bolts on a harley.. 10mm batter terminals, 6mm hex bolt up inside the bottom of 41mm shock lowers... prob a few more.. like the caliper bolts n such 12 point...
