Tire Pressure
Old Aug 31, 2008 | 10:42 PM
colo1032's Avatar
colo1032
Default Tire Pressure
I apologize in advance, but since I don't have an owners manual or service manual for my 2005 Deuce, can anyone advise what the correct tire pressures should be (Dunlop 21" Front & Dunlop 17 " Rear). According to markings on the tires the frontshould be 40 psi and the rear 42 psi. Does this sound right? They each had about 32 psi and I filled them to above numbers, but want to make sure. Thanks
Old Sep 1, 2008 | 12:23 AM
Other Sheep's Avatar
Other Sheep
Kind of depends on if you're riding solo or with a passenger. On my Heritage I ride with about 35 in the front and 38 in the rear. I think 42 is a little high.
Old Sep 1, 2008 | 12:40 AM
Kevinc's Avatar
Kevinc
My 06 manual says for the Duce run 30 psi front and 36 rear for solo, and 40 rear and 30 front for 2 up.
Old Sep 1, 2008 | 12:41 AM
cpbiw's Avatar
cpbiw
look for the sticker on the frame, should be on the down tube somewhere near the voltage regulator, it will tell you what pressure to run.
Old Sep 1, 2008 | 08:15 PM
colo1032's Avatar
colo1032
Thanks all. CPBIW, found the siticker and it advises 40 psi rear and 30 psi front.
cajun1957a
Nov 28, 2016 05:24 PM
Ramez
Feb 24, 2011 07:00 PM
jgcable
May 16, 2010 10:51 PM
tvan1988
Sep 2, 2008 11:14 AM
chivohead666
Jul 24, 2007 06:56 AM
