I can probably get up to 225, but I always fill up aroung 175. (per Tank) on the train- usually I put in 3.5-4 gal at that point.
I am not a gambling man and do not like to push my bike.
I was getting about 50-55 when I first got the bike... Been down in the low 40s lately. It's that time of year when the EPA makes NC monkey with the gas so things have been weird.
I get about 45mpg with fuel injection and stage 1. All depends on how often I get on it! I usually fill up after 150 miles or so, I never let it get too low. Like in a car, the fuel helps cool the pump in the tank.
45 is what i get with a stock bike. When I loaded up for Bike Week and ran down the freeway at between 75-80 it went down to about 40. I have never tried to run over 200 miles on a tank, and the most I have put in the tank is 4.2 gals. I know that the lit. says 5 gals in the tank, but I don't know if you can actually get that much in the tank. I bought an LED fuel gauge which only gives you lighted dots for the level indication, so you can't watch the gauge as it "passes over" a level mark... can't tell if it's "just getting there" or "sitting on the mark" or "just past the mark" <grin> so I stay on the safe side and let my butt determine how far I'm going between stops.
I did get a Soft Bottom pad (single layer) for the ride to Daytona... without it I wasn't interested in more than 6 hours in a day. With it, I did 13 and my hands and feet were giving out before my butt did. I still stop about every 100-120 miles, so that's what usually determines miles per tank for me unless I stop at a Rest Area, then I don't go over 200.
I've got an 06 FXST that is getting around 45 mpg. It has V&H shortshots with rejetted carb. I also have the windshield that adds more wind resistance.
