At a recent rally I saw a Heritage with a heel shifter that was angled down at the rear allowing for less of lift of the foot to upshift. Has anyone seen these and/or know where I can get one.
I've never seen one but I sure can understand where you're coming from. After a days shifting with the heel my left hip starts nagging me bigtime to stop shifting.
My problem is after adjusting the shifters I can't upshift easily with the toe anymore so I'm dependent on the heel shifter. I would like to have the choice of going heel or toe.
The stock positions when I bought the bike where geared for toe only. I've readjusted everything and now it's heel only.
Plane- The one I saw was perfect. It was extended length and the peg basically curved off the floorboard so nothing hit the board and looked like it took only a minimal foot lift. Probably custom fabbed; I have not seen anything like it since.
Nope. That's not it. I saw that site before and it won't work with my setup. I really think this was custom because I have not been able to find anything like it anywhere . I'll probably pick up an extended length shifter and try something custom from there.
Here's what the extended shift levers look like. Keep in mind mine is a special setup-boards and heel/shift on a Dyna. This shift lever will actually move the peg further back on the softail. Problem with mine was at the lowest comfortable setting, the peg was hitting the board= no shift
I know what you mean. I adjusted mine to a great position, took off out of the drive way and couldn't shift... bottomed out on the board. The extended shift might solve my problem. Thanks for starting this thread. Opended a new possibility for me.
