leaking fuel sender
Old Sep 20, 2008 | 06:44 PM
mgsteele@alltel.net's Avatar
mgsteele@alltel.net
Stage I
Question leaking fuel sender
I have a 2000 softail standard and while I was fueling up today I noticed fuel leaking from the fuel sender wire in the bottom of the tank. Has anyone had a simalar problem? and how do I fix it?
thanks
Old Sep 20, 2008 | 08:35 PM
hogdoctor's Avatar
hogdoctor
you have to disconnect the wiring connector for the gauge, pop the fuel level gauge up and out of the tank, under it you will find the sending unit screwed in with five small torx (I'm guessing T20) screws, each has a nylon washer and a cork gasket under the sending unit. First try snugging down each of the five screws, clean out the gasoline, fill up and look for leaks. If it persists, you may have to replace the gasket and screws.
Hogdoctor
13RoadKing
Electrical/Lighting/Alarm
May 19, 2017 04:22 PM
Bradt
Feb 10, 2015 12:28 PM
eefx
Nov 10, 2014 12:21 PM
diiulio
Exhaust System Topics
Aug 4, 2007 03:56 PM
sodapopstone
Apr 25, 2006 12:50 AM
