Slow Jet Size
Old Sep 21, 2008 | 03:52 PM
hfdsod's Avatar
hfdsod
Default Slow Jet Size
2003 Night Train with Short Shot Exhaust. Previous owner put exhaust on, Screamin Eagle Stage 1 kit, and changed Slow Jet to #48. I took it into my Harley Dealer this week for starting problems, and they changed the jet to a #45. Good or bad move?
Old Sep 21, 2008 | 05:29 PM
robzuc97's Avatar
robzuc97
I imagine when you say "starting problems" that it's symptom was "cranked but would not start"-otherwise they were a long way off from the starter! If it is running good, then all is well.
Old Sep 21, 2008 | 05:31 PM
bigoscycles's Avatar
bigoscycles
Go with at least a 46, 48 was probably right. Did the 45 fix the starting issue?
Old Sep 21, 2008 | 05:51 PM
acchd's Avatar
acchd
A #48 is the norm for a stage 1. I am wondering if they compensated the jet for actually another issue.....
Old Sep 21, 2008 | 07:50 PM
hfdsod's Avatar
hfdsod
Ok here was the problem. Bike started fine when I first got it out to ride. The problem happened after I would ride for awhile then stop for gas or a break. After the bike sat for 5 to 10 minutes it didn't want to start unless I turned the throttle a lot and pushed start at same time. I also checked the plugs and it was running really rich. They were solid black around the threads. I took it to Harley and told them what it was doing and they said that the carb was probably getting loaded cause of the #48 jet. So thats why they changed it to a #45. I guess they know what they are talking about. I am new to carbuerated bikes. Let me know what you guys think
Old Sep 21, 2008 | 08:36 PM
crazybastid83's Avatar
crazybastid83
Dyno jet kits usually come with a 48 slow, so most dealers are used to using it. The 46 is far more appropiate for a simple stage 1.
Old Sep 22, 2008 | 08:13 AM
kemosabe2's Avatar
kemosabe2
The PO of my bike had installed a dynojet kit and I was having the same problem. I rebuilt the carb, changed the slow jet to a #46 and the high speed to a #185 and installed a stock emulsion tube. No more problems and the fuel economy is alot better.
Old Sep 22, 2008 | 09:06 AM
robzuc97's Avatar
robzuc97
Black around the threads isn't unusual. It's the electrodes that are the telling. Black on my plugs meant "lean misfire" (changed to the #48 on both bikes) but now have tan-tipped with black threads & both running great!
Old Sep 22, 2008 | 10:08 AM
tk353's Avatar
tk353
I think each bike is different and that is why some get dyno tunes. If it fixed the issue and runs great then it was right.
Matt1200R
Jun 15, 2013 08:53 PM
misput
Mar 31, 2013 07:05 PM
hfdsod
Exhaust System Topics
Sep 21, 2008 07:55 PM
kawsakimx6
Feb 5, 2008 09:55 PM
detailshop
Aug 8, 2007 07:35 PM
