Cruising around
Old Sep 23, 2008 | 11:28 PM
jmwilson's Avatar
jmwilson
Default Cruising around
I use to have a 69 Harley Electra Glide. The throttle did not have return spring. I could let go of the handgrip, and the Harley would cruse. Do the new Harleys like the Fat Boy or Heritage Classic have a throttle return spring or can you put cruse control one of these?
Mike
Old Sep 23, 2008 | 11:37 PM
whylee's Avatar
whylee
I would not recommend running without a throttle return spring. Its easy to get and install a cruise control devise, they are offered by many manufature's.
Old Sep 24, 2008 | 04:39 AM
dbleagle's Avatar
dbleagle
I had a '70 the same way... loved the no throttle return spring...
Run both my Sportster and Bones with the throttle stop tightened up where they don't return by themselves...
But don't think I'm going the cruise control thing though...
Charlie D.
Old Sep 24, 2008 | 05:01 AM
2wheels4ever's Avatar
2wheels4ever
Mine has a throttle return spring. It also has a thumbscrew that you can tighten to keep the throttle from returning too easily or quickly. It will also reduce the play in the throttle. I leave mine with a little play and don't adjust while riding. I also use a throttle rocker on the grip so I don't have to keep a constant grip, just pressure.
Old Sep 24, 2008 | 07:50 AM
Slowpoke84's Avatar
Slowpoke84
I wouldn't ride myself without the throttle return spring. However, I put apes on my old Road Star. The first thing I did was get rid of the throttle return cable. I may do the same when I put apes on the Heritage.
1NewHDGuy
Jun 16, 2014 06:46 PM
mrfikser
Apr 5, 2011 07:34 AM
ionate
Aug 18, 2009 05:08 PM
plane
Aug 12, 2008 10:08 AM
Streetrunner
Feb 17, 2008 03:22 AM
